Correct Spark Plug For Mini Converted To Electronic Ignition
Posted 21 July 2016 - 10:34 AM
Posted 21 July 2016 - 12:43 PM
You should change to the one with resistor in it which is denoted by the extra R.
https://www.ngkspark...stor-spark-plug
I can't comment on the heat range i.e. the number as do not know what state of tune your engine is.
Posted 21 July 2016 - 01:02 PM
Posted 21 July 2016 - 01:15 PM
why do you think you would need to use the R version?
what electronic ignition system is it?
Posted 21 July 2016 - 01:27 PM
Posted 21 July 2016 - 03:55 PM
If in the slightest doubt fit the R version, as radiating ignition interference is highly antisocial, illegal (there are prosecutions from time to time) and dangerous, because the interference can upset computers and such like on nearby vehicles, possibly causing uncommented acceleration or ABS malfunction. Any yes, effects such as these have really been observed.
In actual fact your Mini is unlikely to be as badly behaved as to upset someone else's car, but if it interferes with Coronation Street or East Enders your neighbour may report it.
Posted 21 July 2016 - 04:06 PM
any less performance fitting the r plug
if using resistor leads
i use the resistor leads but non r plugs
lucas electronic, has been good
Posted 21 July 2016 - 04:09 PM
Luckily, we don't have Coronation St or Eastenders here in Italy.In actual fact your Mini is unlikely to be as badly behaved as to upset someone else's car, but if it interferes with Coronation Street or East Enders your neighbour may report it.
Thanks for the interesting info.
Posted 21 July 2016 - 04:13 PM
I have lumenition coil and leads (silicone) fitted. What do you mean by resistor leads?any less performance fitting the r plug
Posted 21 July 2016 - 04:15 PM
Why do you think you need to change your plugs?
So far I have seen nothing to suggest that you need to.
Posted 21 July 2016 - 04:16 PM
The coil and silicone leads are Lumenition. The electronic part in the distributor is from mini spares and is either Aldon or Lumenition. I think these kits are all very similarwhy do you think you would need to use the R version?
Posted 21 July 2016 - 04:19 PM
I will ask again.
I also have a 91 Cooper with carb, electronic ignition as standard and I fit the r plug. I just thought that this would also apply to a dizzy conversion
Posted 21 July 2016 - 06:01 PM
As previously posted this link from NGK tells you when you need to change to R type resistor spark plugs. This is from the manufacturer so I think they will know best!
If you have resistor ignition leads then there is no need to have them in your spark plugs as well as you already have the resistor part.
Edited by Orange-Phantom, 21 July 2016 - 06:41 PM.
Posted 21 July 2016 - 06:53 PM
Posted 22 July 2016 - 09:19 AM
I would check what colour your spark plugs currently are before changing to a colder heat range. I've swapped from 8's to 7's because they were too cold a plug and that is on my 7 Port with an SW10 cam, billet crank etc. and putting out some serious power.
My brother uses 7's on his very highly tuned road racer and they run absolutely spot on so on a mild state of tune engine you may find the 6's are the correct plug. As I said checking the colour will help give you an idea if the rest of your engine is in a good state of tune..
http://www.apriliafo...37&d=1341312352
