Firing Order Vs Plug Location
Best Answer bigfish , 13 July 2016 - 03:12 PM
Thank you all for the help. Nicklouse hit the problem on the head. I moved the drive over a tooth and everything fell into place. Started right up and had initial dynamic timing of 14, I backed it off to 10 as per instructions. My curve stated 20 degrees at 2000, checked that and was right on. Thanks again. This forum is the best! Go to the full post
6 replies to this topic
#1 bigfish
bigfish
  • 33 posts
Posted 12 July 2016 - 11:52 PM
Can someone please confirm firing order 90 1275 non cooper s. SparK plug closest to radiator is # 1 the next to the left , further away from the rad is #3 then 4 and farthest away from rad is # 2? I am getting frustrated installing a 123 dizzy. My helper removed old dizzy and cap plus wires without noting correct position or timing rotor location. Thanks.
#2 nicklouse
  • 18,574 posts
Posted 13 July 2016 - 12:00 AM
Firing order 1342
1234 Rad to clutch.
#3 MacGyver
MacGyver
  • 1,027 posts
Posted 13 July 2016 - 05:42 AM
This might help as a visual guide...
Attached File  MiniEngineManualNumbered.jpg   34.34K   55 downloads
Ps: ignore numbers, picture from the Web.
Edited by MacGyver, 13 July 2016 - 05:44 AM.
#4 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 13 July 2016 - 05:56 AM
From
http://www.theminifo...-lead-sequence/
Edited by timmy850, 13 July 2016 - 05:57 AM.
#5 bigfish
bigfish
  • 33 posts
Posted 13 July 2016 - 01:13 PM
I have been working on the car and when I follow instructions, have #1 at TDC , slide the dizzy , the rotor is in the 10- 11 o'clock position. If I replace with old dizzy rotor is in 2 o'clock position . It is almost as I have to reposition the drive on the bottom of the distributor. Could this be the case? I would have thought a mini specific part number dizzy would have been correct unless there is a diffrence between the 850,1000,and 1257 .thanks for your help
#6 nicklouse
  • 18,574 posts
Posted 13 July 2016 - 01:20 PM
Sounds like the drive in the block might need moving over a tooth. as per the info in your Haynes manual.
as the drive rotates as it is fitted it can take a couple of goes till you get the rotor correct when you fit the dizzy.
#7 bigfish
bigfish
  • 33 posts
Posted 13 July 2016 - 03:12 PM   Best Answer
