Posted 11 July 2016 - 09:56 AM
Absolutely not! If you have anything electronic on the car, especially stuff like an ECU for fuel injection or mapped ignition, severe damage can result due to earth voltage drops in the wrong places. I currently work for a manufacturer of such things. There is also the need to consider any unsafe failure modes that will happen if one of the wires breaks.
The only satisfactory way is to create a "star point" which will be a nice meaty bolt somewhere suitable. The driver's side bulkhead or inner wing area may be suitable. The battery earth and engine earth strap, both as thick as the main battery cable, must have heavy crimp lugs fitted and be the first on the bolt. I would put them together directly, lock washer and nut on top. Then on top of that, stack the various earth returns that I shall list shortly, each with its own properly crimped tag, followed by a lock washer and nut. A 5/16" or 8mm zinc plated bolt is adequate, a brass or copper bolt even more so, if it will take enough torque to stay tight for ever. Give it a good coat of vase line or Waxoyl when finished.
Now to the individual earths. One from each front light cluster, same thickness as the blue/white headlight feeds. Go up a size if using spots. Left side, indicator, head, spot on one wire. Right on another. Dashboard, depending on type, may be more than one black wire. Extend them individually to the star point. Give the radio a nice meaty ground of its own.Each tail light cluster an individual wire. One of these will carry number plate lamp too, if there are seperate left and right fuses that will determine which. Do NOT share the fuel tank earth with anything else. Add extra wires for odd things like interior lamp as needed. Individual wires from any ECUS that are fitted.
That way there should be no spurious interactions due to earth voltage drop, nothing damaged, and both headlights not failing simultaneously.
Avoid the temptation to fit the star point bolt to the front subframe. It will cause some starter and alternator current to take the alternate path through the diff, driveshafts, hub bearings and top arms, and that will very seriously shorten the life of at least the hub bearings. The subframe should be electrically isolated.
