Knocking Sound When Decelerating
14 replies to this topic
#1 Mini Oll
Mini Oll
  • 65 posts
Posted 30 June 2016 - 09:08 AM
Hello,
I have just put my standard mini 850 back on the road.
I only bought the car in March and it has been off the road for at least 12 years, so don't know the history all too well.
It drives great but when taking foot off the accelerator there is often a knock in the exhaust tunnel. i have had a look at the exhaust which seems solid and not hitting the bodywork.
Any ideas much appreciated.
#2 nicklouse
  • 18,583 posts
Posted 30 June 2016 - 09:11 AM
engine stabilizers not fitted or rubbers failed.
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
engine steady rubbers gone? try moving the engine by hand and see if it moves.
Edited by alex-95, 30 June 2016 - 09:11 AM.
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 30 June 2016 - 09:19 AM
If you have a friend ,get them put it on the clutch bite and off see what moves.
Make sure the cars not going move while ya under it or in front of it...............
#5 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 30 June 2016 - 09:32 AM
As above, or engine mounts.
#6 Mini Oll
Mini Oll
  • 65 posts
Posted 30 June 2016 - 10:18 AM
Cheers guys.
Engine moving loads, you can clearly see the rear steady rubber is shot.
Is it just a case of replacing the rubber? Looks pretty straight forward, no little issues or anomolies anyone can think of?
Thanks for your help.
#7 alex-95
alex-95
  • 6,025 posts
Posted 30 June 2016 - 10:29 AM
Pretty much, just the bolts can be rusted so spray them with penetrating fluid and loosen them a tad, tighten them, loosen etc until it comes undone.
#8 Mini Oll
Mini Oll
  • 65 posts
Posted 30 June 2016 - 01:19 PM
Just pre-emepting the next issue. I have ordered new bushes and taken the steady out. I have managed to prize the old rubbers out. Is there a trick/technique to get the new ones in? Or do they actually go in OK with a little help?
#9 ukcooper
ukcooper
  • 1,625 posts
Posted 30 June 2016 - 02:33 PM
Swear a lot, use a long nut and bolt with washers to make a sandwich and squeeze the rubbers into place - washer-rubber / rubber washer nut bolt spacer down the middle
#10 Mini Oll
Mini Oll
  • 65 posts
Posted 02 July 2016 - 08:39 PM
I have fitted new polyurethane bushes and the engine is solid as a rock.
No change in the test drive, still a knocking sound from the tunnel quite far back below the rear seats. I have put my hand on the tunnel and forced the noise and can definitely feel what can only be the exhaust knocking.
I have then jacked it up once home and the exhaust seems solid enough. There is some movement but no more than I would expect.
It appears that it must be the exhaust?!?
Am I missing something.
May take it to my local exhaust place to fully check it out.
#11 Awdition
Awdition
  • 10 posts
Posted 03 July 2016 - 03:27 AM
Hi Mini Oll, I'm having exactly the same problem - a knocking sound from the rear tunnel when decelerating. You can hear the exhaust hit if you put your hand on it. The previous owner fitted an aftermarket exhaust, and when I looked underneath the car I noticed that the seat belt (I think) bolts are just about touching the exhaust....
I think this is the problem...please let me know what your local exhaust place says...
Thanks!
#12 Mini Oll
Mini Oll
  • 65 posts
Posted 03 July 2016 - 08:18 AM
Ahhhh, the bolts!
That would make sense, certainly regards the location.
Will still take it in to see if any ideas.
#13 Mini Oll
Mini Oll
  • 65 posts
Posted 04 July 2016 - 03:58 PM
It turns out the middle bracket was cracked.
£5 for a new bracket fitted and now sorted.
#14 Awdition
Awdition
  • 10 posts
Posted 05 July 2016 - 12:42 AM
Awesome! thanks.
#15 Awdition
Awdition
  • 10 posts
Posted 15 July 2016 - 10:09 PM
..just got a saw and hacked off the excess seat belt bolt that was touching the exhaust.....problem solved!
