I've been slowly getting in with my Mk1 restoration.. The inner wings are in and now I need to get the inner A-panels on, so the rest of the front can be fitted.
I've got the panel tacked on on the passenger side, with the door held where I want it as a guide so the bolt holes line up etc and the hinges fit.
image.jpeg 51.4K
31 downloadsDespite getting everything lined up nice, I then noticed that the curved edge doesn't meet the seam along the sills...
image.jpeg 51.3K
25 downloadsPlus then there is a gap into the sills...
image.jpeg 48.99K
22 downloadsAnd then there is a huge gap when I try the outer A-panel against it...
image.jpeg 41.54K
24 downloadsBasically, it sounds like and obvious question... But does the bottom of the inner panel need to step out and cover the opening of the sills? In the first photo, you can see that the fold in the inner panel lines up agains pt the fold in the inner wing, which I thought was how they were meant to go together...
Any guidance would be great!
Chris
