Is there a secret to this ?
My A+ 1275 Metro block/head were in the original BL red, and after a desultory attempt with paint-stripper seemed to get them clean - although still resolutely red - I used POR15 Engine Paint from Frost to turn them both yellow.
HOWEVER ! Despite several coats (the stuff is hopeless at the "single-coat" covering they claim) and a good period of drying, gentle warming etc - as soon as the engine got really hot the yellow started to go slightly orange, and almost red where there had been lots of red BL paint.
This was the beginning of the problem - just above the petrol-pump orifice, the effect of a heat-gun within the block, inadvertently left for about 30 secs against the wall, started going orange.
The red was working itself into the yellow, and whilst the POR15 gave a satisfactory shine it a) wasn't yellow any more, b) stained really easily (including anti-freeze) and c) chipped very easily.
And once it had got SERIOUSLY hot, the thing began to look pretty naff.
SO since the motor is apart again, I decided that I stood more chance of getting a stable colour if I painted it ............... red.
I've now started using copious quantities of the most hideous paint-stripper known to French paint-suppliers, and am on my second treat-and-scrape session, but whilst I can get the yellow off pretty easily, the original BL red is still sticking like proverbial s to a b.
Has anyone got any experience of a solution / a product that really does get rid of this ?
Obviously it can be removed with enough rotating wire-brushes and emery sleeves, but that seems a ton of work to remove red paint !
And I won't use bead-blasting on any sand-cast engine cases, having seen many years ago what (sometimes) happens.
