#16
Posted 05 June 2016 - 08:36 AM
#17
Posted 05 June 2016 - 09:46 AM
You could mock it up on the actual head,
Release an end rocker, measure the lift on the push-rod and see what valve compression it would give at the various angles with rocker slid clear of the valve. You'd probably have to rig up an extension for the shaft, or slacken of the lot and slide it clear, but that'd be necessary anyway, if you want to try fitting shims without unseating the gasket.
A simple bit of trig will also give you an idea. 80thou divided by adjuster ball to rocker axis distance is the tangent of extra tilt the skim is giving. At a guess it's only 3 or 4 degrees.
#18
Posted 05 June 2016 - 04:17 PM
Crikey fellas, you have me worried enough to pile in with a small hijack.
I have a 12g295 with 0.0935" 2.38mm milled off the face. I have 1275 valves that are 3.26mm longer so I intended to fit 3.26mm rocker and spring shims to nearly correct the geometry. Now i`m thinking 2.38mm post shims to get the pushrod closer to the rocker arm
#19
Posted 06 June 2016 - 06:39 AM
#20
Posted 06 June 2016 - 10:33 AM
But in every case the geometry is defined by the valve seat position and valve length, neither of which change just by skimming the head, even by a large amount. That only affects the adjuster and push rod length.
If you have deepened the combustion chambers and had the seats recur so the valves remain flush, then, and only then, have you created the situation where a shim is necessary, although a shorter valve would be preferable if spring free travel was ok. Nothing else, apart from combustion chamber deepening, or a seemingly pointless head top side skim, can affect the valve to rocker geometry.
Special high ratio rockers which move the pivot point should not need shims as the new rocker shaft pillars should be the correct height. But perhaps not...
#21
Posted 06 June 2016 - 05:48 PM
Ac
Edited by ACDodd, 06 June 2016 - 05:50 PM.
#22
Posted 06 June 2016 - 08:33 PM
#23
Posted 14 January 2017 - 09:08 AM
#24
Posted 14 January 2017 - 10:28 AM
In your original post you mention that you adjusted the tappets but the rockers seem higher at the push rod end than they should be.
Putting shims under the rocker pedestals would make them even higher at the push rod end.
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Mini Technical Sections →
Problems, Questions and Technical →
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
