Can't quite make out in the pics (apart from the oil pressure sender is disconnected) but witch way round are the leads on the plugs? As no1 is at the radiator/water pump end of the engine.
! Update ! Engine Swap - Am I Missing Anything?
#46
Posted 27 June 2016 - 09:31 PM
#47
Posted 27 June 2016 - 09:32 PM
#48
Posted 27 June 2016 - 09:34 PM
#49
Posted 27 June 2016 - 09:51 PM
1-3-4-2 anti clockwise, starting from the top right position on the cap (or 2 o'clock).
That's on the cap, but on the head/plugs it should be 4-3-2-1 radiator.
As for the carb, the float bowl is built-in and on the bottom under the plate with 4 screws. Although you could try fully winding in or out (can't remember with on the hiff38) the mixture screw and then backing it out 2 full turns. As for you now you just need to get it to run and then fiddle with the timing and fuelling properly.
#50
Posted 27 June 2016 - 10:00 PM
#51
Posted 28 June 2016 - 08:32 PM
Still won't start though 😞
#52
Posted 28 June 2016 - 08:34 PM
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 electrical |
Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 electrical |
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
