I'd have a look at the 65 that's fitted. It's a better unit and quite well sealed, so looks could be deceptive. The correct coil is GCL143 or equivalent (1 ohm)
Good call on the water pump pulley and it looks like you'll also need a dipstick.
Posted 02 June 2016 - 07:33 PM
Posted 02 June 2016 - 08:20 PM
Posted 02 June 2016 - 08:36 PM
Edited by CAU998, 02 June 2016 - 08:38 PM.
Posted 02 June 2016 - 09:26 PM
If the engine is standard in terms of head and cam, I'd suggest one of these dissys;-
http://minispares.co...|Back to search
They do also have them available with the electronic module.
Though if tuned, Mini Spares do have a range that may suit.
I've tested a number of 'new' distributors in recent years, most are not really what they say they are for. I've tested a few now of those from Mini Spares and found every one bang on. I also recon they are well priced too.
Posted 02 June 2016 - 10:01 PM
Personally I'd stick with the electronic dizzy on the 1275 (if it cleans up and works) and use the correct 12v GCL143. I might also have a few spare small 'top hat' water pump pulley spare if you get desperate for one.
Edited by 1984mini25, 02 June 2016 - 10:14 PM.
Posted 02 June 2016 - 10:07 PM
Posted 02 June 2016 - 10:44 PM
Posted 03 June 2016 - 06:24 AM
Posted 03 June 2016 - 09:41 AM
It looks like it's a 3 pin "Junior Power Timer" connector; you could try one off another car.
Posted 03 June 2016 - 06:38 PM
Struggling to get hold of the wiring loom for this distributor. I know minispares stock these (https://www.minispar...|Back to search) but seems quite extortionate at £20 and can't seem to find anything on eBay. Any ideas?
You can pick them up on eBay, simonbbc springs to mind.
Posted 03 June 2016 - 08:11 PM
Posted 05 June 2016 - 10:57 AM
Posted 10 June 2016 - 10:27 PM
Hi there.
3 way junior timer connectors can be found on RS / Farnell etc and quite a few old fords / rovers in scrap yards.
Tyco and bosch make these connectors and terminals.
Just type in "3 way junior power timer connector" into google
The application of wires seals and the rubber boot make these connectors waterproof
Posted 19 June 2016 - 07:13 PM
Posted 20 June 2016 - 07:42 AM
Anyone know if the engine mounts are same, if I'm doing this swap? Or are they different?
all the same
http://www.minispare...ounts.aspx|Back to shop
worth buying the nuts and welding them to the new mounts, this makes things a lot easier
Mini Technical Sections →
Problems, Questions and Technical →
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 electrical |
Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 electrical |
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
0 members, 5 guests, 0 anonymous users
