I've got an electronic speedo fitted (not Smiths).
Since I don't have a mechanical takeoff I fitted a magnetic pickup and 12 magnets around the pot joint.
Easy to calibrate and fit and none of the GPS legalities to worry about.
Posted 07 June 2016 - 08:00 AM
Posted 07 June 2016 - 11:49 AM
For those wanting a bit more info on GPS issues and legalities, please see the old thread linked below.
http://www.theminifo...meter-question/
Posted 07 June 2016 - 10:42 PM
Off hand I forget who has them, but there is an after market electronic speedo that uses both GPS and a sensor. It defaults to the GPS signal and when the signal gets 'iffy' then it works from the sensor, once it can get a decent GPS Signal, it swaps back. Apparently, it's all seamless. I'll see if I can find it again.
I think the issue of legality would vary from country to country, not sure and I not going there, but I would suggest that who ever may be contemplating a conversion, seek some proper advice and information from the relevant vehicle standards authorities.
As we all should regarding most vehicle modifications.
Posted 08 June 2016 - 10:21 AM
this sounds like the ideal solution.Off hand I forget who has them, but there is an after market electronic speedo that uses both GPS and a sensor. It defaults to the GPS signal and when the signal gets 'iffy' then it works from the sensor, once it can get a decent GPS Signal, it swaps back. Apparently, it's all seamless. I'll see if I can find it again.
Posted 09 June 2016 - 07:37 AM
For those that are interested here's a photo of the magnets attached to the pot joint.
Clean and rough surface with a dremel and acetone, and then place magnets fairly evenly and coat with exopy resin. Attach sensor.
speedo magnets.jpg 40.23K
35 downloads
Posted 29 October 2023 - 03:30 PM
I know its not strictly to do with the title of this thread. I have always thought about installing abs on a mini and thought about inboard sensor rings to detect wheel speed. Your idea of sticking magnets onto the pot join achieves what I was thinking about possibly a custom pot joint with a bolt on sensor ring.
