Powder Coating Chrome Bumpers?
14 replies to this topic
#1 jamiepaulsmith
jamiepaulsmith
  • 65 posts
Posted 28 May 2016 - 06:25 PM
Does anyone have any experience with this, as I want to Powder Coat them a different colour (gloss or silk black) but am unsure whether the paint will adhere to the chrome plating very well? I suppose you would need to get them sand/shot blasted first?
I would of course just purchase a set of black or nimbus grey bumpers, but these seem much harder to come by.
Likewise with the door and boot handles. I am considering buying a set of chrome ones and powder coating these also.
Any advice on this subject would be great.
#2 minivan2007
minivan2007
  • 208 posts
Posted 28 May 2016 - 06:47 PM
Wont stick to chrome so well so you would be better of getting the black or grey ones
#3 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 28 May 2016 - 06:57 PM
Yes you would probably need of get them blasted before hand.
As for the handles, I'm unsure whether powder coat would be the way to go as the thickness of the powder coat may interfere or stop the locking mechanism form being installed or turned.
Hope this helps.
Ian
#4 jamiepaulsmith
jamiepaulsmith
  • 65 posts
Posted 28 May 2016 - 07:00 PM
Could get the door handles cerakoted? Much thinner but a lot more expensive.
#5 1984mini25
1984mini25
  • 8,784 posts
Posted 28 May 2016 - 09:51 PM
You might find blasting won't be as effective as you might think at removing the chrome and the nickel/copper plating, and might find you have to get them chemically stripped instead.
#6 jamiepaulsmith
jamiepaulsmith
  • 65 posts
Posted 28 May 2016 - 10:50 PM
Could get very costly just to have some different coloured bumpers. Rather annoying that the black or grey bumpers seem quite hard to get hold of.
Second hand ones are generally rotten too.
#7 jamiepaulsmith
jamiepaulsmith
  • 65 posts
Posted 28 May 2016 - 10:51 PM
Might be worth getting a set of stainless steel bumpers instead?
#8 midridge2
midridge2
  • 1,794 posts
Posted 29 May 2016 - 02:33 AM
Flat the chrome with  600 W&D then etch prime then primer and flat back with 800W&D then paint, done it many times.
#9 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 31 May 2016 - 07:14 PM
What about using plastidip? Not a perminant solution, but cheap and easy to redo
#10 andrewmini67
andrewmini67
  • 144 posts
  • Local Club: West Country minis
Posted 31 May 2016 - 08:53 PM
Had my bumpers powder coated and they were sand blasted before hand. Turned out very nice to be honest.
Have experienced a bit of marking/scratching if hit too hard though.
Don't think the handles would be a good idea as it probably would start to come off quite easily.
#11 Italianjob
Italianjob
  • 215 posts
  • Local Club: Not a member yet.
Posted 01 June 2016 - 04:42 PM
Someone posted a couple days ago that you can get them from euro car parts for about £25 a bumper, not sure if you've seen that or not?
#12 jamiepaulsmith
jamiepaulsmith
  • 65 posts
Posted 02 June 2016 - 05:01 PM
Hi ItalianJob, are these black or chrome ones? I'll take a look, cheers
Edited by jamiepaulsmith, 02 June 2016 - 05:01 PM.
#13 59 Speed
59 Speed
  • 674 posts
Posted 02 June 2016 - 06:14 PM
http://www.eurocarpa...798f0d10
http://www.eurocarpa...b91ae4bf
I think you can 15% off too.
Edited by Smackfiend, 02 June 2016 - 06:15 PM.
#14 Italianjob
Italianjob
  • 215 posts
Posted 02 June 2016 - 07:47 PM
That's the ones! Far cheaper than a diy job I'm sure and yes there's codes all over the net for discount, you might even find them on carparts4less which is apparently cheaper but mail order only, I've not looked though. Hope I've helped 👍
#15 jamiepaulsmith
jamiepaulsmith
  • 65 posts
Posted 05 June 2016 - 10:57 AM
Thanks for your help on this guys. Really appreciate it
