Vaseline?
7 replies to this topic
#1 grahama
grahama
  • 2,442 posts
Posted 23 May 2016 - 06:41 PM
Hi all,
Before I tape these together to protect the connection is it ok, electrically speaking, to put Vaseline inside the spade joint to keep the water out ??
https://www.dropbox.....49.17.jpg?dl=0
Thanks,
Graham
#2 fikasteve
fikasteve
  • 124 posts
Posted 23 May 2016 - 06:59 PM
Sorry the pictures not showing for me so not certain where you mean. However Vaseline on the contacts itself will be an insulator so wouldn't work. You can connect them and add it around the outside to prevent moisture ingress.
A better product would be contralube 770. It's a conductive gel that protects contacts. I would then wrap the terminals in heat shrink or such to provide another means of keeping the joint sealed.
You can find contralube 770 here http://www.autoelect...27/category/154
14 quid for a tube but a little goes a long way. I've done all my connectors on my mini and still have loads left.
Hope this helps
#3 pete l
pete l
  • 1,368 posts
Posted 23 May 2016 - 08:06 PM
Vaseline absorbs moisture so no don't use it
#4 grahama
grahama
  • 2,442 posts
Posted 23 May 2016 - 08:35 PM
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 23 May 2016 - 08:37 PM
Vaseline does not absorb water.  It is a refined grease and excludes moisture.
https://en.wikipedia...Petroleum_jelly
 It is insoluble in water.  "
Vaseline can be used on electrical connectors.  Yes, it gets into the gaps between the mating metal surfaces.  However, on spade (Lucar) and bullet type connectors it is easily pushed out of the way by the metal to metal contacting surfaces.  Vaseline is very similar to the dielectric and "bulb" grease purchased specifically to exclude moisture in static electrical contacts.
Dielectric grease is a bit better for use in static connectors as it is typically silicone based and therefore very hard to wash out of the joints once applied.  However, I would not use it or Vaseline inside a switch.
The Contralube linked by Fikasteve would be a good choice for all around use as it would be good on both connectors and switches.
#6 Swift_General
Swift_General
  • 871 posts
Posted 23 May 2016 - 09:17 PM
Vaseline will do you fine for what you need. Or this stuff which I use (albeit for a slightly different purpose).
https://www.amazon.c...3/dp/B000BMTGW0
#7 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 26 May 2016 - 05:03 PM
Used to use Vaseline on the connectors connecting rally car bonnet pod lamps. Didnt want those failing by getting soggy!
#8 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 26 May 2016 - 07:14 PM
We used to put vaseline on all the battery terminals on our trains at work, but since changing from wet type batteries to gel, we don't do this anymore.
