1997 Rover Spi Rover Ac Problems
Best Answer Gary33031 , 15 September 2017 - 01:22 AM
I apologize for not posting the success I had with my AC system. After finally getting the AC schematic, i was able to pin the problem down to the AC Thermostat module that plugs into the evaporator. If you open the passenger round air vent and look inside with a flashlight, you can see the simple connection. I guess I should have started at that end first. Any way, I now have a spare brand new compressor, AC relay, AC Control Switches, another new AC thermostat and a new compressor fan. Living in Florida, it is so nice to have a properly working AC system that blows ice cold air.
Go to the full post
#16
Posted 28 May 2016 - 02:15 PM
#17
Posted 23 June 2016 - 09:04 PM
#18
Posted 24 June 2016 - 09:20 PM
#19
Posted 24 June 2016 - 09:21 PM
#20
Posted 28 June 2016 - 12:00 AM
Where do u get a new drier assembly and switch? Can you provide more detail, l have the same problem with my SPi, the clutch keeps cycling rapidly.
Posted 29 June 2016 - 01:36 AM
What year is your Mini SPI?
#22
Posted 29 June 2016 - 01:55 AM
Just an FYI, I have been able to find all of the parts I need for my AC system at http://www.dinky.co.jp/. They should have parts you need. There response is fast and they are good to work with. I am drilling down to where I think my AC problem is. I replaced the drier and the pressure switch. Had the system evacuated and recharged. I also had ordered the elusive AC relay and swapped that out with the old relay. Problem still wasn't fixed. When I studied the wiring diagram for the AC system, I noted that the binary pressure switch is also connected to the AC thermostat unit. I fortunately have located a new thermostat unit and I also ordered a newAC control switch. When I have parts in hand, I'll take it to my Mini guy. In order to install these 2 components, you have to remove the dash fascia. Not in my tech skills. I'm pretty sure my Old AC relay is good, so I will keep it for a spare. I know compressor is good, pressure switch is good, AC relay is good and now I will install a new control switch and AC thermostat. I'm hoping I have finally tracked down the source of my problems.
#23
Posted 02 July 2016 - 07:16 PM
Posted 01 September 2016 - 08:45 PM
Hey man thanks a lot for all the info...wasn't logged in on the forum for a while...so l am now reading your messages.
Did you solve the problem?
Appreciate it. Cheers
Edited by kommander, 01 September 2016 - 09:38 PM.
#25
Posted 03 September 2016 - 10:06 PM
Gary33031 thanks for the link to Dinky and the AC PDF info - I've recently bought a Jap spec 1999 built car and the air con doesn't work. First issue I have is replacing a metal pipe that runs from the Evaporator inside the car to the joint on the bulkhead. This looks like its part of the Evaporator, so I will need to remove all of that and either see if I can get someone to repair the pipe or I'll have to find a new Evaporator unit, probably from Japan !
#26
Posted 20 December 2016 - 02:50 AM
Hi great thread for me at the moment. My recently imported 98 Cooper has an AC issue that appears to have occurred in the factory. The speedo cable was routed in front of the evaporator pipes and wore clean through one of the tubes. Must have happened a while back so hoping it is the only issue, else I will be fault finding pressure switches etc.
For reference I have found a British guy who lives in Japan who sources Mini parts for us with JDM minis. He sourced me a new old stock evaporator unit and had it shipped to Australia. I am planning to change the unit over xmas and hope to take a few pics as I have not found anything about the evap removal on the forums.
A/C HP line with speedo cable groove cut in it. This also caused one of the fuel lines to rub against the heater hose so will be replacing that also. Have relocated the cable behind the AC hose now as per the pic.
#27
Posted 21 December 2016 - 09:24 AM
My AC system was also engaging erratically, and after searching for possible solution (including the relays for the blower and compressor) it was found that actually the Thermostat Control Unit (usually mounted on the left hand side above the blower unit) is the culprit. I cannot find the exact model for my car (a 1990 Mini) as it's a different type with the injected/1275cc cars. What I did then is to buy a new generic thermostat unit and reroute the wiring to bypass the original thermostat.
#28
Posted 27 December 2016 - 12:21 PM
The thermostat control is the most common fault on the AC system. Had mines replaced as well.
#29
Posted 15 September 2017 - 01:22 AM Best Answer
#30
Posted 04 December 2017 - 11:53 PM
Great to hear you resolved this! As a fellow Aircon mini owner, I dread the day I need similar investigation!
