hey guys,
After removing my spark plugs last time on my SPI, i looked in the plug holes and realised i have a little puddle of oil at the bottom of my dished pistons... the engine has been fully rebuilt about 3k miles ago. I thought it was my valve seals so removed the cylinder head, changed all valve seals, and new head gasket, but no improvements there. I did a compression test on all four cylinders and get around 14.5-15 Bar at all 4 cylinders which is quite good. If my rings were the problem would I be able to have such high compression values? Thought it might be the engine breathers throwing oil back in the Throttle body so tried driving with the breathing system disconnected and going in a can, but no real results there aswell still oil in my cylinders. Feeling a bit confused, Anyone have any suggestions? PS: the car doesn't even smoke that much really.
cheers
