Coolant Temp Sensor - '95 Jdm Spi
12 replies to this topic
#1 Frodo1963
Frodo1963
    Just On Tickover
  • 7 posts
Posted 16 May 2016 - 09:02 PM
My coolant sensor is plumbed into the heater hose, between the thermostat housing and the heater control valve. Is this the normal position on a JDM SPI? It seems it would only detect the correct temp when the heater valve is open. Thanks, any help is much appreciated.
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 16 May 2016 - 09:18 PM
I maybe wrong but I'm sure it's supposed to be under the inlet manifold.
#3 FlyingScot
FlyingScot
  • 2,664 posts
Posted 16 May 2016 - 09:23 PM
Right let's clear this up, what year is it ?
Does it have a distributor or coil pack ?
Steve220 under inlet manifold is SPi system and earlier JDM, I'm suspecting post 1996 model....
FS
Edited by FlyingScot, 16 May 2016 - 09:23 PM.
#4 Frodo1963
Frodo1963
    Just On Tickover
  • 7 posts
Posted 16 May 2016 - 09:41 PM
Thanks for the replies!
It is a 1995
A/C
Automatic
Distributor ignition
Engine number 12A2DJ35322064
I believe the motor and gearbox are original.
#5 FlyingScot
FlyingScot
  • 2,664 posts
Posted 16 May 2016 - 09:48 PM
Well that's torn it!
Is it definitely the water hose we are seeing?
Should be as Steve220 wrote be under the inlet manifold....for engine coolant temperature sensor. You should be able to reach down on rhs (as you lean in) and feel it there.
FS
#6 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 17 May 2016 - 01:07 AM
It is underneath the intake manifold, shown on the left:
#7 Frodo1963
Frodo1963
    Just On Tickover
  • 7 posts
Posted 17 May 2016 - 01:25 AM
I found the CTS under the manifold, thanks Rocket. Wiring appears intact.
So, I wonder what that other sender is for. Hmm.
#8 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 17 May 2016 - 07:38 AM
Trace it, does it go back to the original loom? What are the colour of the wires inside?
Edited by Steve220, 17 May 2016 - 07:40 AM.
#9 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 17 May 2016 - 03:23 PM
Well, mine is a Japanese 1994 with manual gearbox and it does not have that.
Edited by xrocketengineer, 17 May 2016 - 03:24 PM.
#10 hungdynasty
hungdynasty
  • 173 posts
Posted 19 May 2016 - 11:46 AM
Mine is 98 JDM, doesn't have this sensor.
#11 dbcool20
dbcool20
  • 91 posts
Posted 19 May 2016 - 02:16 PM
Do you have an additional temp gauge installed in the car?
#12 Frodo1963
Frodo1963
    Just On Tickover
  • 7 posts
Posted 19 May 2016 - 07:24 PM
No additional temp gauge. There is a dash mounted switch to turn on the electric fan in the left wing. I will try to trace the wires.
#13 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 20 May 2016 - 01:02 AM
Hmm... I wonder if the radiator is not original an does not have the provision for the fan thermal switch. Check behind the grille, the front lower corner of the radiator for two blade connectors on the plug switch. See  the picture. There should be a black wire and a light green/white wire connected there.
