Tim Oil Pressure Gauge Not Working Correctly
Posted 16 May 2016 - 08:32 PM
Posted 16 May 2016 - 09:30 PM
Posted 16 May 2016 - 09:33 PM
FS
Posted 16 May 2016 - 10:10 PM
This is the video of the oil gauge startup and I've attached an image of the sender, sorry I've never done anything like this, and the instructions supplied are less than helpful, thanks
Edited by BravoEchoNovember, 16 May 2016 - 10:22 PM.
Posted 17 May 2016 - 04:55 PM
If you're still stuck at the weekend, send me a PM, we could possibly meet up to see if I can help you. I'm not too bad on electrics
I'm just north of Oxford
Posted 18 May 2016 - 12:27 AM
I watched your video. I also looked online to see if I could find instructions... I could not.
What I do see are red, black, and green wires. Typical aftermarket color codes would be black to earth, red to +12V, and green to the sending unit.
I did not see any attached image to your post here. Can you post a picture of the back of the gauge (and its wires) and a picture of the sending unit?
Posted 18 May 2016 - 07:42 AM
https://youtu.be/O1_JKC45pRw
can you copy the instructions? scan or photo.
and as above.
Posted 18 May 2016 - 09:32 PM
I haven't a dash bud, if I haven't resolved by a week or two, can i come visit you when i have the dash in?
Here are the pics of the instructions and sender:
Posted 18 May 2016 - 09:38 PM
Posted 18 May 2016 - 09:40 PM
Posted 18 May 2016 - 09:59 PM
Red 12V to Gauges red wire, Black negative to gauges black wire, signal from sender (supplied with gauge) to green wire on gauge, the water gauge works off the same power supply, im at a loss at the moment
Posted 19 May 2016 - 04:00 AM
Is the voltage from the other gauges actually 12V or is it higher/lower?
Posted 19 May 2016 - 09:28 AM
If you can't get it sorted, I'm very willing to have a look.
Basic check, if you disconnect the black wire to the sender, what does the gauge do ?
Normally it would not move as the gauge is measuring the resistance of the sender to earth & the gauge would be seeing infinity as a resistance.
If you have a multimeter you could check the resistance of the sender, which should change when the engine is running.( with the wire from the gauge removed & isolated)
Posted 19 May 2016 - 04:24 PM
I thought I typed a reply earlier but it doesn't seem to have posted.
Is the water gauge another aftermarket piece or is it an original Smiths type? This question goes along with Timmy's question above.
