What's the best oil for a '98 MPi?
Edited by RichMPiBlue, 15 May 2016 - 07:07 PM.
Posted 15 May 2016 - 07:07 PM
Posted 15 May 2016 - 07:12 PM
Valvoline VR1 20w50 is my choice.
Posted 15 May 2016 - 07:13 PM
Posted 15 May 2016 - 07:20 PM
It will most likely leak out so quick use the cheapest stuff you can get.
Never had an oil leak on mine and I use the cheap stuff. But I keep hearing the slightly more expensive stuff is the dogs lol?
Posted 15 May 2016 - 07:25 PM
Posted 15 May 2016 - 07:27 PM
I put some fancy stuff in one once, never leaked before but did after, thick green mineral stuff from now on, I like the Halfords stuff.
What's it called from Halfords.
Posted 15 May 2016 - 07:29 PM
You cant miss the halfords one, its in a nice classic style tin.
Cheers.
Posted 15 May 2016 - 07:51 PM
I've used the Halfords stuff before, works a treat and holds good oil pressure when fresh. The reason I use VR1 is because I find it holds better oil pressure after 500-1000 miles whereas the Halfords stuff didn't. I do have an oil leak but a very very slight one.
You can't go wrong with the Halfords stuff as it is good and cheap, I just use VR1 for peace of mind and the fact I use my car daily I would like it to have a quality oil.
Posted 15 May 2016 - 07:56 PM
Posted 15 May 2016 - 08:10 PM
Posted 15 May 2016 - 08:41 PM
Comma classic 20w 50 or Millers Minisport 20w 50.
Posted 15 May 2016 - 08:55 PM
As far as I know the Halford's one is made by Comma, so is the Wilkinson's Classic 20W50, but its normally only £16 compared to Halford's & Comma for about £20
Posted 15 May 2016 - 09:21 PM
Posted 15 May 2016 - 09:33 PM
Make sure it is an oil formulated for the combined engine and gearbox of the Mini as few modern motor oils include the necessary gearbox protection additives like this Millers Trans M20w-50.
http://www.minispare...O1.aspx|Back to
but for better gearchanges, etc you can use this Millers CTV 20-50w semi synthetic oil produced especially for Minis where it needs to lubricate both engine and gearbox parts giving the neccessary coating and protection. Semi synthetic has a long life with maximum working temperature of 130-140c (except on rebuilt engines where pistons must be allowed to bed in first using the non synthetic oil above).
http://www.minispare...01.aspx|Back to
Edited by mab01uk, 15 May 2016 - 09:36 PM.
