I've been trying to replace the reverse light switch in the remote change gearbox, since the previous one stopped working. However, when trying to screw the new one in it won't go in far enough - the spring is pushing the switch closed well before it is screwed in.
I believe the spring isn't going down far enough into the gearbox, but having removed it (and the plunger) and re-fitted it, the spring still extends too far out. I can't see why anything would be obstructing it, but something must be! Any ideas?
