Suspension/steering Geometry
33 replies to this topic
#31 Spider
  • 14,838 posts
Posted 04 July 2024 - 07:41 PM
is it possible to translate mm's on the front/rear toe to degrees please, i.e. what I would see on the hunter machine,
thanks
#32 imack
imack
  • 2,103 posts
Posted 04 July 2024 - 08:38 PM
Again, this time set for 12" wheels.
#33 stuart bowes
stuart bowes
  • 2,102 posts
Posted 04 July 2024 - 09:42 PM
thanks so would that be somewhere between 0° 05'  to 0° 12then for the fronts (toe out)
and 0 to 0° 05for the rears (toe in)
am I reading that right  (and does anyone care to weigh in on which end of that range is the better bet for standard if slightly energetic road driving)
my earlier maths error would make sense then in that as spider's reference points out you measure further out, not at the rim .   hence the angle reduces
Edited by stuart bowes, 04 July 2024 - 09:46 PM.
#34 68+86auto
68+86auto
  • 899 posts
  • Local Club: Queensland Mini Car Club
Posted 04 July 2024 - 10:32 PM
Ignore all mm/inch measurements as there are multiple ways it is measured, some at 24" diameter. The workshop manual does specify a diameter though.
The front toe out is 14 minutes (60 minutes to a degree). The rear toe in is about 30 minutes.
Edited by 68+86auto, 04 July 2024 - 10:39 PM.
1 members, 1 guests, 0 anonymous users
    PaulF
