Quick question, and sorry if it sounds silly...but, when toe in/out is mentioned, is it per wheel....or.....total over both??
So for rear toe in, the figure above says 1/16th, is that per wheel or total....so 1/32 each wheel to make up a total of 1/16
And, when Caster is mentioned as 3 to 3.5 degrees, over what steering angle change? I.e measured as one complete turn of the steering wheel in each direction then record camber change..
Only asking as I think the suspension geo settings my car is set to is giving too much caster, it is a little unstable if swerving to avoid something in the road but is fine everywhere else (feeling of it wanting to 'tuck under')
And a little too much rear toe in, mine is 3.2mm total..
Edited by M111OWW, 13 January 2017 - 04:39 PM.
