998 Head Gasket Compressed Volume?
5 replies to this topic
#1 dantiri
dantiri
    Just On Tickover
  • 9 posts
Posted 05 May 2016 - 05:38 AM
I have a composite gasket CF070L sold as Lucas brand and I'm trying to figure out the compressed volume. Can't find anything on the internet. I measured the gasket , it's 1.45mm thick, but who knows how much it compresses once torqued down... fire rings are egg shaped, so good luck with calculating the volume anyway. any help would be much appreciated!
#2 coopdog
coopdog
  • 4,506 posts
Posted 05 May 2016 - 09:13 AM
It's about 2.8cc crushed
#3 Cooperman
  • 23,194 posts
Posted 05 May 2016 - 06:26 PM
When doing c.r. calcs I always use 2.7 cc for a 998.
#4 dantiri
dantiri
    Just On Tickover
  • 9 posts
Posted 05 May 2016 - 08:21 PM
Thanks. I've seen the Payen copper ones which actually specify 2.8 but wasn't sure it was a common number for most 998 gaskets.
#5 Michaelacaby
Michaelacaby
    Starting My Mini Up
  • 3 posts
  • Local Club: Michaelacaby
Posted 09 August 2018 - 07:06 AM
The old standard O.E. replacement steel shim gaskets are .018" compressed. I forget exactly what the Mr. Gasket steel shim gaskets squish to, but right in that area.....
#6 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 09 August 2018 - 01:03 PM
   A payen copper gasket fire-ring measures 0.030" crushed [off] which works out at 2.7 to 2.8 cc
Yours is quite thick at 1.45mm (0.057") I have just measured a composite one at 0.050" it certainly won't crush to 0.018"
I would calculate at 3cc [near enough for lads]
