Clubman Micra Cg13De / Cga3De Build
61 replies to this topic
#31 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 28 May 2016 - 06:12 PM
You don't hang around do you, probably the fastest micra build I've seen!
Very nice finish to everything you have done. you happy with the swap? Even though it's standard for now.
it's quick when you can buy everything in one go :-)
Edited by Shingler4596, 28 May 2016 - 06:12 PM.
#32 alaskanow0
alaskanow0
  • Just Joined
  • 70 posts
Posted 29 May 2016 - 07:44 PM
Yep wilwood pull. From rally design. Not sure on the part number
#33 alaskanow0
alaskanow0
  • Just Joined
  • 70 posts
Posted 03 June 2016 - 09:52 AM
Another checky video. On way back from passing MOT
https://youtu.be/lDTEIzkeRPE
#34 McMini 22
McMini 22
  • 289 posts
Posted 03 June 2016 - 11:49 AM
Sounds great!  More vids please.
#35 Artstu
Artstu
  • 837 posts
Posted 06 June 2016 - 01:37 PM
It'll be interesting to hear your thoughts about how it compares to the various A-Series engines you've had in the car, once you've done a few miles.
#36 alaskanow0
alaskanow0
  • Just Joined
  • 70 posts
Posted 07 June 2016 - 08:11 AM
Having already covered about 300miles within the last week I can say I'm throughly enjoying just driving the mini. Partly not having to worry about reliability with expensive a series engine builds and 2nd it's a really good strong engine with torque everywhere. You can drive around at 1.5k in 5th or at 7k for every year change. The difference compared to the Micra is night and day.
It's doesn't feel slow compared to my last turbo engine, which was my worry. Unlike the turbo is totally predictable and you can drive it hard without the brown pants. It eats hills up without any issues. Top speed so far 94mph, but would do more. Private road of course.
Only Issues are -
Solid mounted Allspeed & rose jointed suspension increases vibrations and I'm still trying to stop small rattles here & where. (But handling is by far better than is every been) Car is setup and corner weighted though.
- Gearing is great for 2,3,4, but unfortunately 1st doesn't have much legs and 5th whilst at 70mph at 3650rpm is better than most minis, its still higher revving for a 5th gear. The Micra is at 3200rpm at 70mph. The answer is probibly a 3.4 custom Final Drive, but it will affect the performance. I'm currently waiting for price from elite transmissions. They will do a better deal if a few people are interested. Plan will be 998 box with better 1st gear and 3.4FD.
- the throttle bodies sound great and must be helping the power, but I can't live with them. It's like SC drop gears, you would really like a switch to turn them off when just cruising on the motorway.
I plan to do some long motorway miles and at the age of 35 I'm getting to sensible. I've got a Fusion inlet currency been made to my spec to quiten things down. It's a bit annoying as the itb setups wasn't cheap, with the Rams and filteration etc.
The tuned engine should give about another 20bhp and increase the revs to 7500rpm. The 12-1CR, worked head and 264deg cam am should provide a good power increase across the Rev range from 2500rpm. The plan is to fit that and gearbox mods st the same time.
Car is off to the rolling road of Thursday, I'll keep you updated!
#37 Artstu
Artstu
  • 837 posts
Posted 07 June 2016 - 09:22 AM
Thanks for the very informative update.  The new final drive could be of interest to a few, the gearing is good from a performance point of view.
Totally with you on the induction noise, great for a few seconds when you're in the mood.
With regard to the induction noise couldn't you mount an air-filter housing above the gearbox with the feed to the front of the car and pipe the feed from the filter to a plenum above the throttle body trumpets. That shouldn't be much different noise wise than a single throttle body on the fusion intake.
Fabulous build by the way. Guessing with your engine building skills you work at the final destination in the video?
I'd not seen this photo posted, so hope you don't mind me posting it here.
Edited by Artstu, 15 October 2016 - 08:24 AM.
#38 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 07 June 2016 - 09:38 AM
There was a conversation a fair while ago when a few of us were looking at different diffs and found the CD16 a Nissan diesel engine used the same gearbox.
The pinion is integrated into the layshaft IIRC so it makes it tricky...
Here's part of various conversations we had about it ages ago, several discussions through different threads.
http://www.theminifo...a-build/page-13
http://www.theminifo...ra#entry3009959
http://www.theminifo...e-45?hl= almera
I did find some part numbers at some point but I haven't a clue where that stuff is now.
the CD16 is a rare thing so finding the parts was tricky but you may have more luck.
<EDIT>
Nope I was wrong again the engine is a CD17 which is why I couldn't find it..
here's another couple of links (probably better than the above links):
http://www.theminifo...uild/?p=2599631
http://www.micra.com...messageid=80024
Edited by fuzzy-hair-man, 07 June 2016 - 09:47 AM.
#39 alaskanow0
alaskanow0
  • Just Joined
  • 70 posts
Posted 07 June 2016 - 10:51 AM
I did consider making a plenum for the ITbs, but I'd already ordered a Fusion plenum for a single 48mm throttle body, I ordered it as I was going to turbo my 5 door Micra for a bit of fun and create the ultimate sleeper. I bought the Micra for the engine, but it's in mint condition with only 40k, so could bring myself to break it just for the engine. I've since bought a BMW coopers S with 220bhp GTT pack and loaded with stuff, so Micra is going along with my everyday chipped 320d E91.
I found a n14 deisel gearbox with a 3.75 final drive, but it was £180, I'm waiting on a price for the custom one. It's not that bad to be honest, and without the induction noise it would be bearable. I'm just used to Modern diesel I guess.
I don't work at that engine place. I was just collecting my 7 port head after having the valve Seats cut for bigger 37mm inlets. I actually sell sofa's for a living.
Edited by alaskanow0, 07 June 2016 - 12:19 PM.
#40 Archived1
Archived1
  • Archived
  • 619 posts
Posted 07 June 2016 - 03:02 PM
One of the tidiest installs I've seen.
Sounds very raucous and looks lively too! Well done mate
#41 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
Posted 08 June 2016 - 04:02 AM
Mine has a single 50mm GA15 TB w/ RC40 exhaust and cat converter and I think the noise is pretty reasonable @ 110km or approximately 70mph, I did have the thought that I'd not want to alter the gearing too much as I'm using a pretty light throttle to maintain speed at 100km in 5th and it puts it in a nice place in the rev range IMO.
I've no underfelt or carpet on much of the firewall / guards so almost a worst case for noise transmission. There's a short 0-100km video on my thread if it helps assess noise (microphone would have been facing the rear though).
#42 Lehto
Lehto
    Starting My Mini Up
  • 2 posts
Posted 08 June 2016 - 09:56 AM
Difference between the CD17 ratios (3.789 final + 0.733 5th gear) and micra 1.3 (3.895 and 0.756 5th) isnt much. ~200rpm @ 110kmh (70mph). So Im also interested in price for custom final drive for this reason. Looked through many RS5F30A gearboxes so far, none have had 3.55 final drive.
Very nice project, I got good ideas from it! I like how clean and well the engine fits to your mini.
#43 alaskanow0
alaskanow0
  • Just Joined
  • 70 posts
Posted 10 June 2016 - 02:42 PM
Unfortunately I wasn't able to get on the dyno on Thursday. I was there all ready but the morning session car had some problems and was due to be raced the following day and was booked on a ferry that evening.
#44 R1van
R1van
  • 89 posts
Posted 27 June 2016 - 05:15 PM
Just waiting for my radiator & catch tank to be made from Concept Racing, and Matty at Fusion for the Throttle bodies manifold, and modified rocker cover.
Next job is brakes, wiring, interior.
Hello,
 Nice build looks tidy.
What brake set up is that ?? what size are they ??
#45 alaskanow0
alaskanow0
  • Just Joined
  • 70 posts
Posted 27 September 2016 - 06:30 AM
Brakes in the photos are Specialist conponents Monoblock, but I've since fitted a set a Cooper S 7.5's due to issues with the caliper catching on the Allspeed Tie Bars.
Had the same problem with a set of KAD 7.9" disc and calipers. It meant the use of rack limiters that were a little to restrictive for tight turns.
Long term plan is to find some better brakes, as the S brakes are just about OK with Mintex 1144's.
