Sealing Compound?
Posted 02 May 2016 - 09:43 PM
It's like a putty, but I can't quite work out what it is or what it should be...
Posted 02 May 2016 - 11:14 PM
Edited by Icey, 02 May 2016 - 11:14 PM.
Posted 03 May 2016 - 07:33 AM
Posted 03 May 2016 - 08:15 AM
Silicon sealant worked fine for me.
Posted 03 May 2016 - 08:51 AM
Posted 03 May 2016 - 09:15 AM
Many thanks - Googling "polyurethane sealant" gives loads of (inexpensive) options so I'm all sorted.
Posted 03 May 2016 - 11:46 AM
If you ever want to remove the panel again (and you likely will), don't use polyurethane or silicone sealant. The Dum-Dum putty will be fine or a minimal amount of butyl caulk (the stuff mentioned Icey mentioned as being available in strips) will work well. If you anticipate removing the panel every now and then, the foam tape that Skoughi suggested would be ideal.
On early cars that hole is left open apart from some cars where a sound deadening kit of heavy vinyl covered felt serves as a cover.
Posted 03 May 2016 - 12:23 PM
Once the panel is in place and fixings tightened then I took a blob of grease on my finger and laid on a smear on the join between the bulkhead and small panel then wiped off excess.
Posted 03 May 2016 - 03:31 PM
Frost sell a box of Body Caulk material in black that stays soft, can also be used round window
regulators makes removal easier quite a lot in box so not expensive.
PU adhesive make it difficult to remove these parts ! and personally don't like anything that says
silicon near car body repairs or paint
Posted 03 May 2016 - 03:57 PM
Posted 04 May 2016 - 04:18 PM
There was a strip seal used on Wheeler Dealers with the recent Morris Minor episode which sealed the metal panels to the wood frame .. that came from the company that makes the ash frames I think. It's probably similar to the stuff used on the Mini in the factory.
I think this is the company as I remember seeing the sign outside and it was definitely Welsh .. http://www.dinefwr-j...rames-woodwork/
Might be worth a call ...
Posted 04 May 2016 - 05:17 PM
Posted 06 May 2016 - 10:50 PM
duct seal works great
Posted 07 May 2016 - 08:06 AM
Posted 07 May 2016 - 12:28 PM
Repeating my earlier advice, choose any such sealant based on the expectation that you will want to remove the panel again. Avoid strong glue-like sealers. After all, your goal is to seal out noise, dirt, and fumes, not make an access panel a permanent part of the firewall.
