Adjusting Disc And Drum Brake Clearance.
28 replies to this topic
#16 nicklouse
  • 18,574 posts
Posted 11 October 2016 - 07:44 AM
I have a further question on rear brakes with the car clear of the ground if I pull the rear wheels in and out I have about half a centimeter free play. Is this normal?
no.
look for where the play is. most likely the radius arm bush.
#17 Cater_Racer
Cater_Racer
  • 423 posts
  • Local Club: HRCR
Posted 11 October 2016 - 07:48 AM
Thanks Nick, so if I find the arm moving its the radius arm bush if not then its further back, ie rear bearings?
#18 nicklouse
  • 18,574 posts
Posted 11 October 2016 - 08:05 AM
Well if your wheel is moving as much as you say it is unlikely to be the bearings as there would not be any bearing left.
bearing play will show as motion in all directions. 12-6 9-3 11-5 etc (numbers on a clock face) radius arm is only in and out at 9 right side of car and 3 left side.
#19 Cater_Racer
Cater_Racer
  • 423 posts
  • Local Club: HRCR
Posted 11 October 2016 - 08:06 AM
Ok, thanks I'll investigate further this morning.
#20 Dusky
Dusky
  • 5,322 posts
Posted 16 October 2016 - 01:28 PM
No
#21 Zuse02
Zuse02
    Just On Tickover
  • 6 posts
Posted 08 August 2017 - 09:02 PM
New to the forum and need some advice on Brakes. I am planning on buying a Mini Clubman 1979. It has dums on the front and I would like to swap out to discs. I have seen some Metro/Turbo front hubs and flanges on ebay. Would these fit as a direct swap over? They have the ball joints already in on both sets.
Thanks to anyone who can give me the answer. Don't want to buy these and find out later they don't fit, also brakes are very important and need to be right.
#22 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 08 August 2017 - 09:10 PM
I see you're a new member, to get a better response you're better off starting a new thread in the technical section with the heading reflecting your question rather than coming in halfway through someone else's thread.
You'll find you attract more responders this way. Good luck with your query.
#23 nicklouse
  • 18,574 posts
Posted 08 August 2017 - 09:13 PM
depending on what you are exactly looking at  metro hub assys are not a direct replacement for a Mini hub assy. some parts can be used. but little with out some machining and conversion pipes.
#24 Zuse02
Zuse02
    Just On Tickover
  • 6 posts
Posted 08 August 2017 - 09:21 PM
http://www.ebay.co.u...GQAAOSwAO9ZPP2l
Here is the link I have been looking at. If you copy and paste into ebay it should come up with the goods. My apologies for piggy backing on others forums unable to see anything previous abut this.
#25 Ethel
  • 25,919 posts
Posted 08 August 2017 - 09:55 PM
http://www.minispare...-AJJ4028MS.aspx
When you chuck in the discs, calipers, pads and CV joints the Ebay offering doesn't look such a bargain.
If it has drums I'm assuming it also has 10 inch wheels, anything other than the above* and you'd have to chuck new wheels and tyres in to the equation.
*not totally true - but as a straight forward bolt on option it is. You should consider new front hoses and spacing out the rear wheels by some method - even with the 7.5" kit.
.... and also, click the link in my siggy (vvv underneath vvv) if you're thinking hitting your piggy bank.
#26 nicklouse
  • 18,574 posts
Posted 08 August 2017 - 10:02 PM
not enough info in that advert. have they modded Mini hubs? if so can they confirm the pivot points are in the correct position? if they are actually Metro hubs then they are not suitable. and then there is the wheel issue.
join TMF+ and get a 7.5% discount from Minispares and get the kit linked above.
#27 Eagebragax
Eagebragax
    Starting My Mini Up
  • 2 posts
  • Local Club: 115353
Posted 17 October 2017 - 08:16 PM
Son is running Bridgestone BT 016 with no clearance issues. The hugger isnt a standard fitment but he reckons that the damage is caused by stones getting picked up by the tyre.
#28 Michaelacaby
Michaelacaby
    Starting My Mini Up
  • 3 posts
  • Local Club: Michaelacaby
Posted 31 July 2018 - 08:43 AM
Dont know about refurbishing brake valve, it is usual on minis that one port is instilled, the disc shaped object is probably a metro clutch damper.
#29 Tornado99
Tornado99
  • 750 posts
Posted 26 July 2020 - 11:23 PM
Just did my rear clyinders and shoes. I followed this video:
12:08
How to Service and Adjust Drum Brakes the Right Way
YouTube app ยท Stevestonmotorco
Feb 18, 2018
https://youtu.be/M02....be/M02bqqNOlkY
