Adjusting Disc And Drum Brake Clearance.
28 replies to this topic
#1 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 24 April 2016 - 02:25 PM
Hi there so I have my car up on bricks and I was just checking the wheels spin freely as I've just replaced the brake servo and master cylinder and before I fill it up with brake fluid I was making sure everything else is ok. The front two wheels which run disk brakes rub as they turn and the back two wheels rub a little aswell. Is there a way of adjusting the clearance on both types of brakes so that the wheel spins freely ?
Kind Regards
George
#2 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 24 April 2016 - 04:40 PM
No adjustment on disc brakes there is nothing to hold the pads off the discs, they will drag slightly. drum brakes there is a square adjuster, tighten till the wheel is locked then back off about 1/4 turn, will still drag a bit
#3 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 24 April 2016 - 04:54 PM
the discs are very stiff and quite corroded as well so maybe time for a new set of discs and brake pads?
#4 monkey
monkey
  • 1,382 posts
Posted 24 April 2016 - 06:13 PM
A picture speaks a thousands words, how much is quite corroded? Lol, discs will get rusty when stood but that will rub off after a few taps of the brake pedal - this is normal. I guess they shouldn't be very stiff, I would remove the brake pads and see if it's still stiff, just to ensure it definatly is the pads/discs causing the stiffness. If it is it isn't nessasarily down to worn/faulty pads/discs, could be a piston siezed in the calliper etc
When was the car last used?
Edited by monkey, 24 April 2016 - 06:16 PM.
#5 WimpyMiniMan
WimpyMiniMan
  • 149 posts
Posted 02 May 2016 - 10:26 PM
I think it is just a little too corroded to leave so i ordered new discs and pads, but the grinding sound was actually from the wheel bearings which i am changing as soon as i get a spare weekend! Also the car was in daily use right up until the brake servo failed so its not like it had been stood for any amount of time.
Edited by WimpyMiniMan, 02 May 2016 - 10:27 PM.
#6 gazza82
gazza82
  • 3,100 posts
  • Local Club: TMF+
Posted 06 May 2016 - 01:50 PM
Discs can get a thin coat of rust overnight when wet .. or from washing the car! It shoudl rub off when you next move the car and use the brakes. If it doesn't you probably need new discs!
These aren't great ... 2013-12-18%2013.07.36.jpg ... ignore the missing piece!
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 06 May 2016 - 04:42 PM
Just a footnote on rear wheels/brakes....  You do NOT want rear brakes (or any drum brakes) to spin freely.
Correct adjustment on drums requires that an elevated wheel can be spun by hand and stop within about 1 revolution.  You should be able to hear a small amount of shoe drag noise as the wheel is spun.  If you adjust the brakes so the wheels spin freely you will end up with excessive brake pedal travel.
#8 MRA
MRA
  • 7,607 posts
Posted 24 July 2016 - 12:45 PM
Disc brake adjustment
The piston seal design is such that it pulls the piston back in once the pressure is released, this is a designed distance to allow a running clearance between the disc and pads.
Adjustment is taken up as the pad wears it slides a few microns through the piston seal and when released it retracts the desired amount.
Therefore pressing the pedal pushes the piston/s out through the seal to allow the pad to contact the disc.
piston movement = seal retraction distance + wear of pad at the specific time you press the pedal, when released the piston retracts (the seal retraction distance) but because of the wear in the pad (the last operation) it moves back to a point that is slightly further out than when you started.
Think 2 steps forward 1 step back each time you apply the brakes.
#9 tiger99
tiger99
  • 8,584 posts
Posted 30 July 2016 - 10:42 AM
I have to wonder who it was that came up with such elegant simplicity, accomplished just by using a square section seal in the cylinder bore? Presumably someone at Dunlop?
#10 MRA
MRA
  • 7,607 posts
Posted 14 August 2016 - 03:37 PM
The first disc brakes where developed in 1890 but serious production didn't start till 1950+ and no information appears to be available about who it was that developed the retraction / seal method...
#11 MacGyver
MacGyver
  • 1,028 posts
Posted 18 August 2016 - 01:15 PM
Wiki's disc brake history is nice.
First development in the 1890's...
Not sure it's specific on the designers and developers other than brand names.
But would be nice to put a name on the inventor. 😀
Maybe someone has an old tech book somewhere...?
Edited by MacGyver, 18 August 2016 - 01:16 PM.
#12 tiger99
tiger99
  • 8,584 posts
Posted 21 August 2016 - 04:32 PM
All I know is that Dunlop made the brakes for the D Type Jaguar which started winning races because of its braking ability, and caused every car manufacturer to take note. By the mid 1960s front discs by Girling or Lockheed (AP) were standard on many cars, even humble Ford Cortinas and Triumph Heralds. Nowadays Dunlop only make aircraft carbon brakes, or at least they did when I last worked across the road in the electronic anti-skid department in the early 1990s.
#13 A-Cell
A-Cell
  • 1,610 posts
Posted 21 August 2016 - 07:17 PM
Frederick William Lanchester patented the disc brake for automobiles in 1902. He used it on his 12hp Lanchester in 1903.
It worked very well but the 'pads' were made from copper and the brakes screeched dramatically.
He made many pioneering contributions to the automobile world, both engines, transmissions and suspension.
#14 Ethel
  • 26,827 posts
Posted 21 August 2016 - 10:11 PM
Glad this topic came up. I've discovered Google have a patent search feature. It's just US patents, they've always been better managed than ours.
#15 Cater_Racer
Cater_Racer
  • 423 posts
  • Local Club: HRCR
Posted 11 October 2016 - 07:42 AM
I have a further question on rear brakes with the car clear of the ground if I pull the rear wheels in and out I have about half a centimeter free play. Is this normal?
