How To Plug Weld
7 replies to this topic
#1 pete l
pete l
  • 1,368 posts
Posted 19 April 2016 - 09:55 AM
hi all.
some of my plug welds are not holding, some of them go pop after and are not welded to the other panel.
what am i doing wrong ?
Pete
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 19 April 2016 - 10:03 AM
Size of hole and power/wire feed speed.
I do not use 5/32 holes, too small and easy to fill with weld rather than getting any penetration. I always use 3/16th or 1/4" holes. A high power setting with wire speed to match.
Having the material clamped together well is also a must.
#3 finch661
finch661
  • 2,339 posts
Posted 19 April 2016 - 12:43 PM
as above. have a look here
i always liked the look of ==>
#4 pete l
pete l
  • 1,368 posts
Posted 19 April 2016 - 02:34 PM
My holes are 7 mm
I'll keep on trying
#5 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 19 April 2016 - 03:06 PM
My holes are 7 mm
I'll keep on trying
If your holes are 7mm then you are not using enough power and suitable wire speed. The other big thing i declined to mentioned the metal must be clean of any paint other then weld through Zinc primer if you are using it.
#6 pete l
pete l
  • 1,368 posts
Posted 19 April 2016 - 03:09 PM
I don't think i need more power as i manage to increase the size of my hole when trying to weld them.
Do i need fast or slow wire speed ?
Ans all clean apart from weld thru
#7 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 19 April 2016 - 03:10 PM
If you are burning back then up the wire speed.
#8 Stu.
Stu.
  • 912 posts
Posted 19 April 2016 - 08:53 PM
If the hole edges are burning out then the panels aren't tight enough together. You also need a fairly high power setting with good wire speed for plug welding.
Start the weld in the centre of the hole, wait to see a nice orange weld puddle then move steadilly in a circle to the outside closing the hole. Look for a small dimple on the rear of the bottom panel, that's a good indication that the penetrations good.
Also I have never got on with weld through primer. I find it messes with the weld puddle and and the arc strikes onto the edge of the hole causing it to blow out.
I get much better results without using it, but I know others have good results.
As you said, practice is the key. It'll click soon enough and then you'll be well away with it.
