Posted 17 April 2016 - 07:37 PM
Thinking of going for magnolia dial faces but am having trouble indentifying my dials.
Car is 1988 mini Mayfair (bit only just got it so no Ida I things have been altered). It has three clocks. 90 mph speedo, centre temp and fuel. Rev counter on right. All work great. There is no marking on the faces to say smiths or Nippon. Any ideas?
Alan
Posted 17 April 2016 - 07:58 PM
A picture would be a great help!
These are Nippons with 90mph speedo:
These are Smiths (though this is a 120mph version, I have the same setup with a 90mph):
Posted 17 April 2016 - 08:03 PM
got to Nippon haven't they on an 88?
Posted 18 April 2016 - 10:44 AM
Hi guys
Thanks for the reply will take a pic this evening. They are 90mph speedo but look like the second set.
I am beginning to suspect they are a bit of both if that's possible. The centre dial (fuel and temp) does not have smiths written on it but the outer dials do have the black edge rings. Any idea if that is possible? Can you fit the rings from the smiths clocks to the nippon gauges/remove the rings from smiths gauges?
I must say I think the Nippon's would be easier to read. As I said I will take pics and post this evening. Need to do something to improve the contrast or, plan b, just ignore the gauges altogether. My first mini just had the big centre speedo (which bounced around all over the show and was just a rough guide) and neither the fuel or temp guages worked.
Alan
Posted 18 April 2016 - 03:45 PM
Alan
Posted 18 April 2016 - 04:24 PM
They are later Smiths gauges, genuine for the car according to this advert:
http://www.newoldcar...limited-edition
Model nubers are BAU5402 (speedo) BAU5404 (rev) BAU5405 (fuel) & BAU5406 (temp)
Posted 19 April 2016 - 12:19 PM
Posted 19 April 2016 - 12:32 PM
Unfortunately can't see any magnolia face kits for those gauges. Might be worth contacting Minispares, Somerford etc. to see if they know of any suppliers.
Posted 27 June 2021 - 07:54 PM
Edited by joekenton, 27 June 2021 - 07:59 PM.
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
Low Compression Across The BoardStarted by Vinay-RS , 11 Nov 2024 engine |
Clutch Parts And FittingStarted by Apeman85 , 10 Nov 2024 engine |
1980 998Cc Engine - Can Someone Willing To Learn Strip And Rebuild An Engine?Started by LukeClassicMan , 04 Nov 2024 engine |
Answered
Low Oil Pressure On Fresh RebuildStarted by sgallegly , 29 Oct 2024 engine |
1995 Spi Clutch Not Disengaging After ReplacementStarted by David12 , 26 Oct 2024 engine |
