Exact Fit Wheel Spacers
Posted 16 April 2016 - 12:32 PM
Posted 16 April 2016 - 01:03 PM
Posted 17 April 2016 - 12:06 AM
Posted 17 April 2016 - 08:00 AM
You'll want a little bit of slack so you can get them off. Drill them one at a time and you can bolt the spacer to the drum to improve accuracy.
Posted 17 April 2016 - 08:59 AM
Posted 17 April 2016 - 01:38 PM
Posted 17 April 2016 - 06:08 PM
Posted 17 April 2016 - 07:36 PM
Posted 17 April 2016 - 09:07 PM
And people still buy them.
Posted 18 April 2016 - 06:24 PM
I know, I know!!! Its not an idea situation. Little background: This car is a Monte Carlo LE. One of the those "LE" items are the painted Rover Mini-lite wheels. I bought the car from W&P and it was fitted with their painted flares. In order to get the car to "look" right, spacers were needed as I really do want to fit aftermarket wheels to it but am ok with the flares as W&P is as classic as the Mini itself. So, there I am.
Counter story, I am thinking of fitting a set of factory plastic arches to it. I have a brand new set of painted one (in Mini 30 maroon) sitting in the shop, still in their packaging. Obviously I would get them painted to match. Nice thing is that I the W&P flares cover the factory holes so I can switch back with no ill effects. If I fit the originals on again, I could (nearly) do away with the spacers all together. I fitted one to my car the other day to see and I think spacers are still needed to "fill" the arches but not the 3/4" ones that I currently have on there.
Nick, as your car looks WIDE, can I ask what you did? Obviously wider wheels with more offset but what about the actual suspension? Have you got longer arms?
Posted 20 April 2016 - 04:12 AM
After I remove the W&P flares and fit the Rover ones, I am going to have these spacers turned down a bit to match the flares and help bring things back in a bit.
Posted 23 April 2016 - 01:21 PM
Came up with a better solution...I am ditching the spacers all together!!! Going to revert back to factory Rover flares (painted) and no spacers. Well, maybe some in the rears if my 165 section tires are too close to the shocks but that will only be around 5mm or so.
Posted 10 June 2016 - 06:33 PM
Wanted to write a follow up to this. As you might have seen in my other post, I finally refit the stock Rover flares and ditched the W&P's. In doing this, I also reverted back to a stock track width. Because I was running such wide spacers, I needed new, shorter, wheel studs all around. As a few of my studs at the rear were loose when the wheel was off, I decided to replace the both hubs, new bearings, and drums and shoes (might as well as they would need it soon enough). For the rear, I went with the Cooper's "handling package" 5mm spacers to be sure there would be no rubbing with the 165 section tires. Got the kit from Mini Sport. They are a perfect fit to the stud. On the front I replaced the studs with standard length ones.
I can't even begin to tell you all what a difference this has made to the car handling. The steering is soooo much lighter. Its amazing the difference. Those ridiculous 3/4" spacers up front were literally ruining this poor car. Drove it in my usual aggressive manner to the office today and it was a dream. Spacers are for the birds...or as Upinforth wrote, "Spacers are the work of the devil." Cant agree more.
