Spare Wheel Solution
29 replies to this topic
#1 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 11 April 2016 - 04:34 PM
Hi guys, we were out at the weekend and my mate got a puncture. Neither of us carry a spare; we both have an inflator canister. The problem was the puncture happened on a dual carriageway and the sidewall was ripped out and they  haven't invented a can that will replace a tyre sidewall. It got me thinking because we're going to France later this year and I don't want to get stuck in the Alps so I've decided to try and carry a spare wheel. I have 13x7 Ultralites fitted with 175/50 R13 Yokohama , I have the 7.5 gallon tank so I don't have a lot of room in the boot when its full of luggage, what have you used to match up with the rolling radius or is there some sort of space saver spare available? I really need some suggestions on this one.
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 11 April 2016 - 04:37 PM
mpi's have a space saver.
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 11 April 2016 - 04:40 PM
How does it work, is it deflated and you need to inflate it? Has anyone a picture of it?
#4 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 11 April 2016 - 04:46 PM
It's just a thin wheel that sits in the tyre well in the boot.
#5 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 11 April 2016 - 04:49 PM
Hi Steve,
Thanks for the pic, do you know what size the tyre is so I can check out the rolling circumference,
#6 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Nope. Someone else will probably know.
#7 dobbin1999
dobbin1999
  • 82 posts
Posted 11 April 2016 - 06:31 PM
I'm pretty sure that the standard spare for an MPi with 13" wheels is a 12" wheel with a 145/70 x 12 tyre which fits in the spare wheel well, there are usually some for sale on Ebay, normally unused because by definition they are for emergency use only.
#8 blackbelt1990
blackbelt1990
  • 2,614 posts
  • Local Club: Minimus Maximus
Posted 11 April 2016 - 06:36 PM
^^^ that's not a space saver, it's a standard 12 inch mini steel wheel.
#9 mab01uk
mab01uk
  • 12,412 posts
The rolling diameter is near enough between all 10, 12 and 13" classic Mini wheels as the tyre wall just gets lower profile/height as the rim diameter goes up........a standard steel Mini wheel and normal 145 tyre will be fine as a spare and was used on the MPi.
Modern narrow spacesavers are for temporary use to get you home or to a garage and come with a speed restriction anyway.
My new BMW MINI has 17" wheels (215/40 x 17) and comes with an optional 115/70x15 spacesaver spare!
Edited by mab01uk, 11 April 2016 - 06:42 PM.
#10 dobbin1999
dobbin1999
  • 82 posts
Posted 11 April 2016 - 06:39 PM
This steel wheel and tyre was standard fitment for 12" wheel Minis from around 1984 - 1996 that didn't have alloys as standard, e.g City, Mayfair, Sprite etc.
#11 greenwheels
greenwheels
  • 687 posts
  • Local Club: Mini Fixers
Posted 11 April 2016 - 06:51 PM
What about a roof rack like the old rally cars. Mini Mail used to do them.
#12 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 11 April 2016 - 06:59 PM
I've never seen a space saver for a mini if i'm honest. Mine is a 12" spare wheel.
#13 A-Cell
A-Cell
  • 1,610 posts
Posted 11 April 2016 - 07:11 PM
Once minis started getting alloy wheels the spare was still a 12in steel wheel with a 145/70 tyre. They were then marked with 80kph or 50mph when installed due to the different wheel/ tyre size on an axle when in use. So effectively a space saver for the 13 inch shod MPi.
So you just need to pick up a 12in steel wheel fit a 145/70 tyre and you have a useable spare that will fit in the wheel well. And yes the wheel will fit fully inflated and ready to go. Put 30psi pressure.
#14 blackbelt1990
blackbelt1990
  • 2,614 posts
Posted 11 April 2016 - 07:12 PM
Yeah, Rover never did a space saver for the mini and there isn't a space saver available for any other car with a 4x4inch pcd.
#15 A-Cell
A-Cell
  • 1,610 posts
Posted 11 April 2016 - 07:16 PM
See Steve220's boot picture, shows figment of spare wheel marked up 80kph as a space saver.
