The ball type are really only for racing, not road use, the reason is because of how each type work or sometimes don't work...
Your ball type will fluctuate, you won't see this on the gauge but the engine will "see" it as pressure waves, this is bad for a road engine, this type are less susceptible to debris in the oil causing the valve to stay open which is good for racing.
Your plunger type which maintains a much better more even flow, allowing better control of oil to your bearings especially at low engine speeds where most road engines seem to spend a lot of their time.
You may notice if you read your Mini history books that neither Morris, Austin, BMC, Leyland nor Rover fitted a cheaper ball type PRV except to the one Cooper S in the 60's everything else was fitted with the more expensive plunger type, none of the companies above spent money when a cheaper option was available unless there was a very good reason for it.
