Micra Engine Fast Road Build
5 replies to this topic
#1 danllew
danllew
  • 41 posts
Posted 06 April 2016 - 06:04 PM
Hi All,
Had a 1986 Mayfair with a 1275 in it for a few years. Had it on the road for a year.
I've decided that tuning the A-Series is too expensive, unreliable and doesn't make great power.
Micra Engine conversion was the best option as most people seem to avoid any major bulkhead chopping and you can keep the inner wings if you want to.</p>
Haven't got a solid plan with regards to setup yet, but I'll definitely be keeping fuel injection, probably using a microsquirt.
But first things first need to build a subframe, here's what I got so far.
Jig to start with:
Front and Rear pick ups using 50x50x3 Angle
bf11a65c-9203-4bff-bf84-79c39abea209_zps
Used some 25x25x2 for the rearward jig mounts
Some weird angles trying to pick up on the rearward mounts
Tie rod pickups, had someone from work knock me up a couple of bushes.
1fcb6cb2-47b0-4722-998b-decb4b99377a_zps
Added some bracing front as back as the jig was flexing too much when I pulled the subframe out
eb110a4e-752f-446a-8dd9-480c74af0dd5_zps
Committed to the chop
0ac9885e-a174-43b9-a2eb-967ebc12c3f5_zps
Front piece is 50x50x2 Box, and the bracing from the towers down to the front is 25x25x2 box.
I'm going to weld a plate into the bottom of the tower to try and stiffen it up its 3mm plate.
From asking a few people I think I'm going to need thicker plate for the suspension mount. Most people seem to recommend 6mm.
Any feedback would be appreciated.
Cheers,
Dan
Edited by danllew, 06 April 2016 - 06:20 PM.
#2 Shingler4596
Shingler4596
  • 221 posts
  • Local Club: South Wales Mini Club
Posted 08 April 2016 - 08:01 PM
Looking good mate!
#3 l_jonez
l_jonez
  • 1,453 posts
Posted 09 April 2016 - 11:10 AM
Nice to see another build
#4 danllew
danllew
  • 41 posts
Posted 03 July 2016 - 05:06 PM
Been struggling to find time and motivation recently, managed to get a bit more done today.
#5 thelegg
thelegg
  • 608 posts
Posted 04 July 2016 - 09:22 PM
Looking smart :)
#6 benm
benm
  • 111 posts
Posted 06 July 2016 - 06:44 PM
looks good! ill be following this as im about to embark on the same adventure :)
