No, I don't measure disc run out. Again, it's not something I can correct that accurately. I can get an idea by spinning the wheel and feeling and how the brakes operate on the road.
If you knew what disc run out is you would realise that it is simple to correct and that with a good DTi you can correct it, simply rotate the disc on the drive flange and if that doesn't correct it rotate the drive flange on the CV assy you will find that there is a "best" fit that will invariably be within the distance set in the workshop manual, which incidentally is also in the haynes manual.
So if you fit your new discs and go down the road and find they are transmitting forces to the pedal what will you do then ?
Edited by MRA, 27 March 2016 - 11:37 AM.
