Slight Oil Leak Coming From Nut On Oil Filter Housing
20 replies to this topic
#16 redboy
redboy
  • 333 posts
Posted 07 April 2016 - 09:11 PM
Ive got a new oil filter housing and braided pipe coming tomorrow. Any tips for fitting or is it pretty straight forward?
One thing ive got to get at some point is a smaller torque wrench :/
#17 redboy
redboy
  • 333 posts
Posted 08 April 2016 - 01:43 PM
Can anyone tell me if removing oil filter and housing will result in a lot of oil loss? I know the filter will have oil in.
So I need to drain engine oil to take the filter housing off?
#18 A-Cell
A-Cell
  • 1,610 posts
Posted 08 April 2016 - 01:58 PM
No need to drain the oil to remove filter housing. The oil level is in the gearbox/ sump which is below this. You will lose a bit that in the filter housing and block oil gallery. Not much more than changing the filter. Don't forget to fit a new gasket between the housing and the block.
#19 redboy
redboy
  • 333 posts
Posted 08 April 2016 - 03:48 PM
Thanks. All off.
I notice the bolts for the housing have blue on the thread. I take it they need some loctite on them. Says nothing in the Haynes about it.
#20 A-Cell
A-Cell
  • 1,610 posts
Posted 09 April 2016 - 08:47 AM
Could be they are patch bolts. Dab of loctite ok.
#21 redboy
redboy
  • 333 posts
Posted 09 April 2016 - 05:56 PM
All done. Not road tested yet though. I enjoyed the Nice little hour and half trip to mini spares as they sent me the wrong oil pipe adapter to start the day.
20160409_145614_zps8cem1jn6.jpg20160409_145555_zpsvfcwtdgz.jpg20160409_145608_zpshet6wkcu.jpg
Just hope the pipe does not start melting the air pipe.
