Slight Oil Leak Coming From Nut On Oil Filter Housing
20 replies to this topic
#1 redboy
redboy
  • 333 posts
Posted 23 March 2016 - 11:30 AM
its where a pipe comes into the what the oil filter screws into. Ive nipped the nut up but there is still a leak. Is there a washer or something than can be replaced?
#2 imaparana
imaparana
  • 580 posts
Posted 23 March 2016 - 11:37 AM
you could take it out and put some ptfe tape on the thread and try again
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 23 March 2016 - 11:38 AM
Drives
Sprite 1275
Replace it with a braised pipe . like this http://www.minispare...classic/braided hose.aspx|Back to search
Make sure you get the right one for you car.
They can pop off and you lose all your oil.
#4 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 23 March 2016 - 11:50 AM
Braided even ... :-)
Check carefully around the connector stub on the filter head. In the past if it's been over-tightened it may have been cracked .. it's only a soft alloy.
Edited by gazza82, 23 March 2016 - 11:51 AM.
#5 redboy
redboy
  • 333 posts
Posted 23 March 2016 - 12:11 PM
wow. dont fancy paying 60 quid for the braided pipe  :X  ill be taking the filter off later so ill have a look. Is there oil in this pipe when the engine is cold?
#6 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 23 March 2016 - 12:43 PM
A bit .. be prepared for bit of leakage ..
#7 ukcooper
ukcooper
  • 1,625 posts
Posted 23 March 2016 - 01:22 PM
That pipe is obsolete. Braided pipe is the only way to go.
think last one I bought was 30ish.
if it pops off or break's and you don't notice very quickly, your going need a new engine.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 March 2016 - 02:24 PM
This is true, the olives on the pipes once crushed cannot be reused, and are obsolete... Replace with the braided pipe is the ONLY off the shelf option.
#9 redboy
redboy
  • 333 posts
Posted 24 March 2016 - 12:30 PM
undone the nut today, wish i hadnt. bits of what looks like thread came out and i couldnt get the nut back in. Eventually got the nut in but its definitly cross threaded.
Does this mean a new oil filter housing and braided pipe?  :X
Im hoping its ok to get me to its MOT tomorow. Cant test it yet as ive just spray painted the rocker cover.
#10 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 24 March 2016 - 04:26 PM
Depends what thread ..  the thread between oil filter housing and double-ended adapter or the thread in the nut that secures the pipe to that adapter ..
And you can often pick up the old pipes on fleabay .. I think I might have a spare lying around ..
#11 racingbob
racingbob
  • 3,061 posts
Posted 24 March 2016 - 04:56 PM
a braided pipe is on my list asap
apparantly gives a better oil flow
#12 redboy
redboy
  • 333 posts
Posted 24 March 2016 - 06:19 PM
There's no adapter. Its the nut that tightens against the olive in the filter housing. The nut is steel so I'm guessing the housing is stripped a little.
The nuts in but it went in at a slight angle. Like said just hope it holds out when I put the oil in tomorrow and gets me to the MOT.
The filter housing is also OOS at mini spares :(
#13 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 26 March 2016 - 10:11 AM
So have you got the old bowl filter with separate element?
The spin-on version has a small double ended adapter between pipe and head ... That's what I was referring to.
So make sure you get the right type of pipe ... (Neither are available new now).
#14 MRA
MRA
  • 7,607 posts
Posted 26 March 2016 - 11:21 AM
No the later ones didn't have the screw in nipple, they are more like a brake pipe with a flare nut straight into the oil filter housing it is a different thread from the earlier similar type.
#15 MRA
MRA
  • 7,607 posts
Posted 26 March 2016 - 11:26 AM
~A tip in future is to tighten both ends a little at a time until they are nipped up and then a final tighten.
