Fuel Pump Torque Setting
8 replies to this topic
#1 crn1969
crn1969
  • 114 posts
Posted 22 March 2016 - 09:22 AM
Hi I'm sure this has been asked and answered but can't seem to find info.anyone know what torque setting for mechanical fuel pump ( the one with plastic spacer) 1989 a plus?
#2 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 22 March 2016 - 09:38 AM
16 lb/ft or 22Nm (according to a Metro manual I have)
#3 redboy
redboy
  • 333 posts
Posted 22 March 2016 - 11:13 AM
just hand tightened mine. with a 1/4" ratchet.
#4 crn1969
crn1969
  • 114 posts
Posted 22 March 2016 - 12:36 PM
Okay is the metro fuel pump the same? I know it's an A plus engine.but didn't know if fuel pump is Un changed?
#5 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 22 March 2016 - 02:39 PM
The picture in my manual looks like a normal mechanical pump!
Do as redboy suggests and nip it up tight with as short a ratchet or spanner as poss. You just need to clamp down the gaskets and squeeze the spring washers.
Edited by gazza82, 22 March 2016 - 02:41 PM.
#6 crn1969
crn1969
  • 114 posts
Posted 22 March 2016 - 04:04 PM
Okay will do .for the record weren't any spring washers on the original.flange bolts I think there called.many thanks.
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 22 March 2016 - 05:05 PM
I don't know about the A+ but all the A's I've seen have spring washers under the nuts on the studs or under the bolt heads if converted .. to stop them coming loose over time. Is yours has studs and nuts, has it got nylok's on yours or plain nuts?
I use the parts diagrams on MS, Moss, Rimmer, etc to see what nuts/washers/studs/bolts/set-screws should be fitted.
#8 redboy
redboy
  • 333 posts
Posted 22 March 2016 - 05:26 PM
Mine has no spring washers either. Just 2 blots. Git to get into so can't really over tighten.
#9 crn1969
crn1969
  • 114 posts
Posted 23 March 2016 - 08:23 AM
Mine has bolts with a flange on them not studs.they look original .have torqued them to about 20 nm.will post if I have any issues when engine is back running.
