They said that the coil pack is new :s I know I paid for a new one last year, but they said they have replaced it in the last few weeks incase it was that thank you though :)
Please Help! Ecu And Wiring Loom :(
#16
Posted 24 March 2016 - 06:22 PM
#17
Posted 24 March 2016 - 06:43 PM
cam sensor is one git of a problem and will cause intermittent issues
#18
Posted 24 March 2016 - 07:28 PM
It's going to Wiltshire!
I would have thought Bristol Mini & Cooper Club would have recommended someone more local, on the upside i've heard of Somerford.... OK i'm joking -everyone whose seriously into their Minis have heard of Somerfords. They WILL fix it.
Also on the plus side: intermittent wiring problems can be a real so&so to locate, if it's now a consistent problem it's easy to find (lets hope this is still the original problem & not a new one your local garage has caused).
From the info i have available to me Pin 25 on the ECU red connector is Crankshaft Position Sensor & Pin 25 on the Black connector is Ignition Coil Pack signal. Chances are it's a fault with a wire or connector as all the components (& everything under the sun) has been changed -but whatever it is you'll soon have the Mini back & working properly .
#19
Posted 26 March 2016 - 12:28 AM
Good info, I would like your comment but have run out of likes yet again.....
#20
Posted 26 March 2016 - 06:58 AM
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
