I'm currently building a mini turbo with a metro turbo engine, I'm doing a bit of research in what turbo to use. I'm tempted to run with a dual ball bearing turbo I've looked at the gt3076r. any other dual ball bearing turbos people would suggest?
Dual Ball Bearing Turbo
Posted 17 March 2016 - 12:00 AM
Posted 17 March 2016 - 08:55 AM
GT3076!!!!
it will never make any boost! far to big, might be ok if you strap 2 1380's together, or go to 16k.
GT2056 is considerd a big turbo for the A series and will easily be big enough for 220hp, some people with 16v heads have managed to run as big as the GT2860 (RS) but I think you'll struggle to find a BB turbo small enough.
GT1752 from the saab 95 is a great turbo for a road car, or the td04 equivalent (bit more durable than the gt17)
as a general rule the last 2 digits on garret turbo's are the compressor wheel diameter which gives an indication of the output, your looking for somthing around 48-58mm, but ideally you need to plot the flow on the compressor map, try this with a ve of 85%
http://www.motorgeek...e&page=flowcalc
Edited by mini13, 17 March 2016 - 09:14 AM.
Posted 17 March 2016 - 10:07 AM
GT3076!!!!
ok thanks, i will stay away from that one then haha
i have a gt1752 which i was going to use, i just like the thought of a dual ball bearing turbo. how much boost are people comfortably running with the gt1752?
Posted 17 March 2016 - 10:34 AM
they are good for 200+, the highest Ive seen recorded is around 240 on the GT17.
they are a good choice as they com on boost quite early so are pretty drivable, the 2056 comes on about 3500rpm
Posted 17 March 2016 - 02:58 PM
ah cool I'm aiming for 180+ so i think ill stick with the gt17, i can always upgrade if i want to in the future
thanks for the advice
