Brake Fluid Capacity
7 replies to this topic
#1 scooby doo
scooby doo
  • 53 posts
Posted 13 March 2016 - 03:47 PM
Hi. I have recently replaced my brake master cylinder and front brake pipes in the engine compartment of my 1987 998 mayfair. I believe i have bled the hole system properly and have used about 250ml out of a 1ltr bottle of fluid. Having never done this before, does this sound about the correct amount ?
#2 David128
David128
  • 644 posts
Posted 13 March 2016 - 03:52 PM
How does the pedal feel?
#3 MRA
MRA
  • 7,607 posts
Posted 13 March 2016 - 03:54 PM
You may need to use a pressure bleeder to get all the air out, how are you currently doing it ?
#4 scooby doo
scooby doo
  • 53 posts
Posted 13 March 2016 - 04:07 PM
Hi yes the pedal feels good and yes i used an easy bleed with 20psi from the spare wheel. just a little surprised by how little fluid i ended up using .
#5 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 13 March 2016 - 04:11 PM
You would be better with someone sitting in the car. :highfive: Ideally you need a professional brake bleeder, but they cost an awful lot of money for the amount of times it's needed. >_<  :shy:
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 13 March 2016 - 06:49 PM
The system takes less than you would think, the pipes are small bore internally and there is t much capacity of the cylinders/ calliper so 250ml doesn't sound too,low. But the key is how they feel, if they are as firm, or better, than before (assuming you didn't do it due to problems) then you are ok.
#7 MRA
MRA
  • 7,607 posts
Posted 13 March 2016 - 06:59 PM
The easi bleeder is great for DIY use.  Great bit of kit, comes with several caps of various sizes.
Much better than a body on the drivers seat, and much cheaper than a professional unit.
https://www.google.c...pLyDoXYU97TqrgE
Edited by MRA, 13 March 2016 - 06:59 PM.
#8 scooby doo
scooby doo
  • 53 posts
Posted 17 March 2016 - 08:30 PM
Many thanks for all your advice and comments
