Is there a noticeable ride/handling difference between van/pickup/estate and saloon?
Posted 11 March 2016 - 12:18 PM
Posted 11 March 2016 - 01:03 PM
LWB tend to be a little more stable and less pitchy at higher speeds / worse road surfaces
Posted 11 March 2016 - 01:08 PM
but as the pick-up is so light at the rear......
the differences are minimal.
Posted 11 March 2016 - 07:34 PM
When you load up the back of an estate with several hundredweight of sand and cement from the builders merchants you do get a totally different handling experience. The steering gets much lighter...
Posted 11 March 2016 - 09:47 PM
You won't notice any difference unless you are flat out on a race track, and even then it probably won't feel any difference.
More difference will be noticed simply by fitting better tyres or better dampers, or even by setting the suspension up more accurately.
Posted 11 March 2016 - 10:03 PM
LWB Minis definitely ride a bit nicer, the difference between a clubby estate and a saloon is very noticeable.
Posted 12 March 2016 - 12:08 AM
As a young feckwit in the 80s I can tell you realworld driving mini LWBs
Well pickups mainly...three people in the back, chanting football songs, who have jumped in ininvited, does not improve handing, until you make a sharp left and they tumble into a road island!.
Handling wise, they are a little more tail happy
Posted 12 March 2016 - 11:24 AM
Same with Mini Marcos, these use the same wheelbase as estate / pickup but at 530kg and much of this in the engine bay have even less weight over the rear wheels.
They are prone to loosing the grip at the rear, and when they let go can be very difficult to catch before they spin.
Posted 12 March 2016 - 11:26 AM
Posted 12 March 2016 - 11:27 AM
Posted 17 March 2016 - 10:28 AM
I have heard Mini-only races banning the LWBs, well the vans at least, not sure about pick-ups, because they are that bit better in the corner. The problem is, as they are typically more expensive, it essentially increases the cost of entry, as you are supposedly at a disadvantage in a SWB. That's the logic anyway.
Posted 18 March 2016 - 10:37 AM
Thank you all for your comments, the consensus appears to be favourable towards long wheel base.
I have not driven or been passenger in either for many years and looking forward to using my Cooper again, which is almost ready for MOT.
The reason for my initial post is I also have a 1966 mini estate I purchased in 1972 that I am considering either selling or restoring.
Posted 18 March 2016 - 12:47 PM
Fun, isn't it!
Most fun I had with a pickup was an A55 pickup with column change that the garage I worked at had as a workshop vehicle.
Posted 18 March 2016 - 09:27 PM
Fun, isn't it!
Your story reminds me of when I was a 18 year old apprentice at a toolmaking firm in Worcester. They had an A55 works van that I borrowed while I was rebuilding the gearbox on my Mini. Unfortunately one of the directors saw me showing off drifting the van round the industrial estate car park! Almost got the sack for that folly
