MRA, I never mentioned my age and who says I took the box out the car?
#46
Posted 12 March 2016 - 05:59 PM
#47
Posted 12 March 2016 - 06:13 PM
No you didn't mention your age therefore you be about 100...... or 15 ? not sure which
lol
My mistake, I was sure you said you had removed it.... oh well what SCCR kit do you have then ?
Edited by MRA, 12 March 2016 - 06:21 PM.
#48
Posted 12 March 2016 - 06:49 PM
I doubt many people on here would want to even sit as a passenger in my car, and that's before the straight cut box goes in and the new engine is screaming at high rpm with no exhaust silencing....or sound proofing
#49
Posted 12 March 2016 - 06:58 PM
Edited by Dusky, 12 March 2016 - 07:03 PM.
#50
Posted 12 March 2016 - 07:00 PM
Well this escilated quickly!
as already mentioned the noise of SC boxes and drops can vary a lot from manufacturer to manufacturer and also depends on other things like how the engines mounted, personally I run the minispares ST kit in a remote box with the minispares timkin drops and a 3.1 diff, Ive never found this setup overly noisy, if fact the other half has reguarly slept in the car on the motorway.
in terms of why do i have this fitted... try putting turbo power through a helical box... the limit seems to be about 150 hp, although the drops seem to last to over 200hp ok if you get the right setup... but no one knew that back when i built the engine.
in terms of drivability, i find it fine, first could be a bit shorter for trafic, but I never really see any in it.
#51
Posted 12 March 2016 - 07:43 PM
Mini Technical Sections →
Problems, Questions and Technical →
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
Su Carb Backfiring/spitting FuelStarted by Adge456 , 25 Jul 2026 |
Main & Be Bearing AssemblyStarted by RCrossley , 11 Jul 2026 |
Head Gasket Or Tappet Cover Oil LeakStarted by crbeasley01 , 25 Jun 2026 |
