Straight Cut Noise
engine
50 replies to this topic
#1 Jon937
Jon937
  • 130 posts
Posted 10 March 2016 - 08:14 PM
Has anyone found a way to reduce the noise from straight cut gears?
Both in the differential and transfer gears as these mesh while not totally submersed in oil.
I had thought about intentionally overfilling the gearbox with oil and installing a breather in the top of the diff cover and transfer gear housing, while using an adjustable oil pressure valve to ensure the oil pressure does not get too high.
My worry would be the crank webs would need to run in more oil and increase drag on the crankshaft, as well as smearing the black silicone on the gaskets to ensure the gaskets can handle the added pressure.
Another idea I had was running a small fluid pump with an additional oil pick up, to spray a constant oil supply onto the gears while the engine is running.
http://calverst.com/...s and noise.htm
Any thoughts, ideas good or bad greatly appreciated please
#2 kezzkitkat
kezzkitkat
  • 714 posts
Posted 10 March 2016 - 08:20 PM
bad idea adding more oil
most are going to say either put up with it  or get rid
ive know people make the tolerance smaller on the transfer gears reducing the noise slightly
also even changing them to another brand
#3 Jon937
Jon937
  • 130 posts
Posted 10 March 2016 - 08:23 PM
Thank you kezzkitkat
What is your thoughts about adding an additional oil pump to spray the gears?
#4 Midas Mk1
Midas Mk1
  • 5,761 posts
  • Local Club: S.U.N.M.C
Posted 10 March 2016 - 08:24 PM
Just change to helical..
Edited by Midas Mk1, 10 March 2016 - 08:25 PM.
#5 Spider
  • 14,665 posts
Posted 10 March 2016 - 08:28 PM
Lubrication is not the reason for the noise.
http://www.theminifo...ears-beginners/
Overfilling or over lubrication will only result in burnt out bearings and poor oil life. The Synchromesh will also have a hard time of it too.
Edited by Moke Spider, 10 March 2016 - 08:32 PM.
#6 kezzkitkat
kezzkitkat
  • 714 posts
Posted 10 March 2016 - 08:35 PM
waste of time rarther spend the money on a decent radio instead
as above moke spider has linked have a read
also the normal or high flow one is more than efficient i think the swiftune one is the one to have at the moment
#7 Jon937
Jon937
  • 130 posts
As Keith Calver has published on his site and in mini magazines is that the FD and transfer gears are not submersed in oil to dampen out the noise.
http://calverst.com/articlefm.htm
#8 Jon937
Jon937
  • 130 posts
Posted 10 March 2016 - 08:37 PM
im looking at using dog gears so there is no syncro to worry about
#9 kezzkitkat
kezzkitkat
  • 714 posts
Posted 10 March 2016 - 08:44 PM
the sc fd are very noise indeed there is no solution to quite them down
the only way would be to consider using a semi fd much quieter  running and just as strong
i assume your going down the lsd route ?
#10 Jon937
Jon937
  • 130 posts
Posted 10 March 2016 - 08:48 PM
quaife lsd
do you know if anywhere does semi helical transfer gears?
#11 sledgehammer
sledgehammer
  • 3,094 posts
Posted 10 March 2016 - 08:55 PM
all I can suggest is thick carpet / sound deadening
& ear plugs
loud exhaust anyone ?
the noise is from the way the gears mesh together
#12 Ivor Badger
Ivor Badger
  • 846 posts
Posted 10 March 2016 - 08:59 PM
So why are you bothered about the noise?
#13 Spider
  • 14,665 posts
Posted 10 March 2016 - 09:00 PM
Hmmmm,,,, maybe Mr. Calver should have another look.
The Main Gear Set and the FD are ~1/2 submersed in oil.
Edited by Moke Spider, 10 March 2016 - 09:01 PM.
#14 nicklouse
  • 18,400 posts
Posted 10 March 2016 - 09:14 PM
Not driving in traffic much then?
#15 Dusky
Dusky
  • 5,322 posts
Posted 10 March 2016 - 09:38 PM
Do us all a favour and produce some herringbone gears. ;)
Or just ditch them if its a road going car, wear earplugs under your crash helmet if not.
