Rotational Metal On Metal Sound
suspension brakes
9 replies to this topic
#1 exeterman2
exeterman2
  • 12 posts
Posted 10 March 2016 - 06:24 PM
I've got a rotational metal on metal sound coming from the front right of my car. It happens when the wheel is turned slightly to the left and also under braking (more noticeable under braking usually). I recently had the front right CV boot replaced as it had a split in it (it hadn't been split for long and i had it immediately replaced when i discovered it) so was wondering it it was the CV joint? I know that my brake pads are fine as that was my first thought when the noise first appeared when braking. It's my daily driver too and from school so any help much appreciated!
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 10 March 2016 - 06:28 PM
Could be the brake pad retaining plate or the CV joint(although these usually click)
#3 midridge2
midridge2
  • 1,794 posts
Posted 10 March 2016 - 06:30 PM
A stone in the stone guards, the big bit of metal that stops stones from getting into the brake discs.
#4 1968cooper
1968cooper
  • 95 posts
Posted 10 March 2016 - 06:48 PM
it may seem daft, but check the metal cv boot securing clip has been trimmed off flush and not rubbing inside the hub casting
#5 Spider
  • 14,836 posts
Posted 10 March 2016 - 07:01 PM
CV seating in the Bearings and the Nut correctly Torqued?
#6 MRA
MRA
  • 7,607 posts
Posted 10 March 2016 - 07:14 PM
Have you checked the pads have any material on them ?
#7 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 10 March 2016 - 08:13 PM
If its a trapped stone, sometimes reversing briskly and a dab on the brakes will dislodge it.
#8 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 10 March 2016 - 10:20 PM
You may want to check the preload in hub bearings; when they wear, the preload reduces, and can cause the drive flange to wobble about, and scrape on the stoneguard.
#9 MRA
MRA
  • 7,607 posts
Posted 10 March 2016 - 10:25 PM
As can worn CV and or worn hub.
#10 exeterman2
exeterman2
  • 12 posts
Posted 20 March 2016 - 10:45 PM
Hi guys, thanks for your advice, forgot to update you all but it was a stone! No more horrible sound! Cheers
Also tagged with one or more of these keywords: suspension, brakes
