ball joint holder thread cross threaded
Posted 22 August 2006 - 04:08 PM
I am fitting new ball joints but in taking the ball joint holder nut on and off to find the correct amount of shims to use the thread on the hub has been cross threaded. I now cant get the nut back on properly.
I obviously dont want to have to replace the whole hub assembly as it has been cleaned, painted, new bearing fitted etc....
is the only solution retapping the thread? and if so does anyone know where i could get on ethat big from or have one i could borrow and i wold pay all postage costs.
What size is the thread? is it 1" 5/16th?
Thanks for looking
Dan
Posted 22 August 2006 - 04:10 PM
Posted 22 August 2006 - 09:08 PM
Instead, call around to industrial suppliers (not DIY centers). I'm talking about the places that supply tools to machine shops. Ask them about thread files. I don't know the thread count on the ball joint portion of the hub, but if you can count the threads per inch on the "good" hub (that isn't buggered) you can tell the supplier what you need. A thread file (as its name implies) is a file whose tooth pattern is spaced to match standard thread pitches. They are your best bet for cleaning up large damaged male threads.
EDIT: See...
http://www.conceptto...px?Category=386
Edited by dklawson, 22 August 2006 - 09:10 PM.
Posted 22 August 2006 - 09:13 PM
hi there you could always try and find a thread file i have 1 i got from a car boot brand new £3 theres 8 different threads on it saved my bacon loads of times Sykes and pickavant make themIm inthe middle of rebuilding my front subframe and the hub assemblies.
Thanks for looking
Dan
Posted 22 August 2006 - 09:14 PM
Edited by Dan, 22 August 2006 - 09:15 PM.
Posted 23 August 2006 - 05:46 AM
I'd get another hub, either from a jumble, a brakers, or see if anyone here has one. I think MiniSport are having a clearance on new ones at the mo.
Tony
