Wing Mounted Mini Solenoid To Metro Combined Starter Motor/solenoid.
Best Answer cambiker71 , 05 March 2016 - 10:25 PM
Yup exactly, the little wire on the wing mounted solenoid starts everything in motion, saves any mods just a simple small jumper cable. :D Go to the full post
28 replies to this topic
#16 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 06 March 2016 - 06:27 PM
I've got a question here;-
Do these particular starter motors work with the earlier 'smash and grab' type ring gears or do they use a different one?
Doubtful, there's a few options, the pitch of the flywheel ring gear needs to match the starter motor though
#17 MRA
MRA
  • 7,607 posts
Posted 06 March 2016 - 06:39 PM
There is a "odd" starter, I have seen a pre-engaged starter motor on an inertia type flywheel, I think it was from an early metro.
#18 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2016 - 07:20 PM
Forget changing lots of wiring, you need one crimp on connector to fit the metro starter solenoid and one eyelet crimp on connector to fit the starters battery connection and about an inch of wire.
Then connect the metro starters battery connection to the exciter connection and bolt the wire from the solenoid on the wing to the starter in the same way as the old mini starter, when the solenoid is switched it will power up the new metro starter too.
Connect as the red marker. Done lots like this. Dead easy.
While the above wiring does work, the wiring as per the diagram above powers the starter motor to spin and engage the pre-engaged drive gear at the same time, which defeats the advantage of the pre-engaged setup, where the solenoid pre engages the gear and then makes the contact to spin the motor.
The wiring above would increase the wear on drive gear and the ring gear and the pre-engaged ring gear/drive gear was never designed to be crash engage.
Whilst the above wiring is easy to install, I'd recommend you wire it as intended with the relay on the wing and loose the old solenoid, or use the old solenoid as a connection point where you remove the wire on the 12v out with the key held connection and place this on the 12v in from battery connection and onto the solenoid on the pre-engaged solenoid, using the old 12v trigger wire to power a starter relay and avoiding problems with current through the ignition switch.
#19 cambiker71
cambiker71
  • 1,050 posts
Posted 06 March 2016 - 10:32 PM
Didn't have any problems with mine working like this Kernow, over 5 years an 60000 miles daily driver usage :D
#20 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 March 2016 - 12:16 AM
You may not have but its not the correct way to run a Pre-Engaged starter Cam
#21 Ethel
  • 26,811 posts
Posted 07 March 2016 - 12:17 AM
It doesn't Dave,
The actual motor  is on the screw terminal and is only connected when the solenoid bridges both screw terminals internally, same as the wing mounted variety. The only difference is the solenoid has to pull the gear into engagement with ring gear before it makes contact.
I'm trying to think if there is a down side. I suppose the wing solenoid will be switching more current so might erode its contacts sooner. There'll also be a bit more resistance pinching oomph from the motor. Can't make my mind up if it will auto disengage any different once the engine starts; the short jumper and thick battery cable might put more volts on the solenoid for motor to cancel out while it's playing at being a generator.
...and a + for doing it Cambiker's way - if the pre engaged starter jams on you can still cut its supply off.
#22 cambiker71
cambiker71
  • 1,050 posts
Posted 07 March 2016 - 06:36 PM
As said before I had five years usage like this before I sold the car. I have 25 odd years as a tech in the motor trade so have a bit of an idea how these things work :D
The wire goes to the usual place on the starter motor, not directly to the motor bypassing the pre engaged starter.
It all works the same as a normal pre engaged starter, the only difference is the main battery power is also switched off when the key is released.
Another bonus is you don't have a permanent main battery cable to rub through on the back of the grill if you use a metro starter motor, the mini ones have the solonoid mounted on top of the motor leaving the wiring up higher and away from harm whereas the metro type has the solonoid mounted further round forward of the engine which makes the wiring fairly close to the grill and front panel (Unless you have a clubman of course)
Edited by cambiker71, 07 March 2016 - 06:37 PM.
#23 MRA
MRA
  • 7,607 posts
Posted 08 March 2016 - 02:36 PM
Before the Mini was fitted with pre-engaged starter motor I welded in a couple of aluminium blocks, machined them level and drilled, tapped two holes so as to turn the starter motor clockwise in the transfer case... not ideal but it did work well and meant I could use the Turbo transfer case and pre-engaged starter....
Edited by MRA, 08 March 2016 - 02:40 PM.
#24 MiniMoe2008
MiniMoe2008
  • 166 posts
  • Local Club: None Around Here
Posted 15 August 2016 - 07:18 PM
Does anyone have pictures on where it hooks up from the wall mounted solenoid?
#25 ultimax5
ultimax5
  • 23 posts
Posted 15 December 2024 - 12:39 AM
I've retro fitted many of our cars with a Japanese Starter Motor and on the Wife's Moke, that's more or less how I did it.
Hi Spider,
Do you know the specific model of Japanese starter motors that you’ve used on your other cars and wife’s Moke? Did they require any modification? I’m considering going that route to replace my ADU9703. Thanks in advance.
Edited by ultimax5, 15 December 2024 - 12:44 AM.
#26 Spider
  • 15,870 posts
Posted 15 December 2024 - 02:22 AM
Hi Spider,
In the UK I * think * they were sold as an Opel Kadett (Here it was the Holden Gemini), you want a starter from the RWD models, made from 1975 to 1984. Until recently, I was able to get these new here.
These work fine with the 107 tooth ring gear that's used with the Inertia type Starter.
There is a small modification you need to do to fit them. It'll take less than 10 minutes with a round file, the mounting holes need moving 1/2 a hole closer together. Other than that, just move the heavy starter cable on the original solenoid to the battery terminal and the White / Red wire to the solenoid on the Starter.
#27 ultimax5
ultimax5
  • 23 posts
Posted 15 December 2024 - 06:28 AM
Thanks for your reply, Spider. I forgot to mention that my Mini is a later Japanese spec SPI (with the coil pack, no dizzy). It uses a pre-engaged starter and I believe the ring gear has 129 teeth, so I guess the starter motor you used wouldn’t work for me.
#28 Spider
  • 15,870 posts
Posted 15 December 2024 - 08:17 AM
Ah OK, gotya. These don't suit that I'm sorry.
#29 ultimax5
ultimax5
  • 23 posts
Posted 15 December 2024 - 08:55 AM
No worries, mate. Thanks.
