Suspension Donut (I'm So Stumped Pls Help!)
42 replies to this topic
#16 MRA
MRA
  • 7,607 posts
Posted 29 February 2016 - 11:57 PM
Theres a nylon cup that sits in the upper suspension arm that the ball on the end of the trumpet sits in. If it wears out then it allows the suspension to drop (quite a lot due to its position on the arm) If you had the donuts and trumpets out it was really false economy not to change them.
Thanks. I dont even remember seeing a nylon cup in there. If that was the problem would it make that much difference to the ride height? the wheel is pretty much touching the arch.
It would be about 25 to 40mm difference
#17 MacGyver
MacGyver
  • 1,027 posts
Posted 01 March 2016 - 12:00 AM
The rubber dust cover should attach to the nylon cup so it should be easy to see if it's in there.
Would make a bit of a drop as it's near the inside of the 'lever' so to speak... 1mm there makes an inch at the end...
#18 New game mini
New game mini
  • 294 posts
Posted 01 March 2016 - 12:06 AM
I'll definitely check that out thanks, only thing that makes me think it was there is that it was sitting ok/better on the old Donut. I'm still thinking it's the Donut, is it possible it could be faulty or are they pretty fail safe?
Edited by New game mini, 01 March 2016 - 12:10 AM.
#19 MacGyver
MacGyver
  • 1,027 posts
Posted 01 March 2016 - 12:13 AM
Depends where you got them? You probably got both from the same place and at the same time right? Could you take it out and compare with the old one?
There are some out there that fail quite quickly (500km or so) but never heard of one that collapsed on fitting...
Must be French...
...Can't always blame the Chinese can we.
Edited by MacGyver, 01 March 2016 - 12:15 AM.
#20 New game mini
New game mini
  • 294 posts
Posted 01 March 2016 - 12:19 AM
Hahaha. Yea bought both together at same time. First port of call is the nylon cup I think, try and get everything lifted back up!! Third time lucky hopefully!! If that fails I might just chuck the old cone back in.
#21 nicklouse
  • 18,583 posts
Posted 01 March 2016 - 12:26 AM
Like I said pictures.
Of the parts not the car.
Without seeing the bits and how they go together comments can not really mean much.
#22 MRA
MRA
  • 7,607 posts
Posted 01 March 2016 - 12:27 AM
Must be French...
It's more likely to be Indian....
#23 New game mini
New game mini
  • 294 posts
Posted 01 March 2016 - 12:34 AM
Hi, obviously everything's back together now but I'll defo get some more up when I can.
#24 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 01 March 2016 - 09:44 AM
Also, even if the cup is in there if the (not visible) base of it is shagged out, then you will get the same drop. If you are getting all the tools out again, I would change both cups anyway, really is false economy not to do so
#25 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 01 March 2016 - 09:52 AM
Attached File  sus-front-complete.png   220.22K   21 downloads
So from this you can see its pretty unlikely the trumpet can get further up the donut
Edited by ChopperHarris, 01 March 2016 - 09:53 AM.
#26 New game mini
New game mini
  • 294 posts
Posted 01 March 2016 - 10:12 AM
have you fitted the donut the correct way up ...
I was just about to say that... :-P
Oh my....well..I've just been back outside to have another look with fresh eyes and errrrrm yeeeeaaa the donuts upside down. I really do feel like a prize boob right now. Feel free to point and laugh. I'm off to punch myself in the face :P
Thanks for all your help folks.
#27 MRA
MRA
  • 7,607 posts
Posted 01 March 2016 - 10:15 AM
Remember ...... sugar side up !
#28 New game mini
New game mini
  • 294 posts
Thanks, defo will, just ordered some from the link you sent. Thanks again.
#29 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 01 March 2016 - 10:35 AM
They can be pigs to hook out sometimes, a hot airgun helps.
#30 MRA
MRA
  • 7,607 posts
Posted 01 March 2016 - 11:07 AM
But not too hot .... I used acetylene some years ago and it really didn't work well at all, but a hot air gun as Chopperharris says is the way to go, it only softens the plastic making it possible to pull it out, hopefully/
