Ride Height
14 replies to this topic
#1 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 26 February 2016 - 06:57 PM
Hi, I've searched the forum and can't seem to find an answer. I need the distance from the ground to the sill trim, front and rear for a 1990 mini with 13" wheels so I can set my hilos to standard height before adjusting the wheel alignment.
Thanks in advance.
#2 brivinci
brivinci
  • 1,179 posts
Posted 26 February 2016 - 10:01 PM
well, it really depends on the tires you are running and their overall diameter. That will make a big difference to the measurement of the sills to the floor.
Also, are you going for stock height? Stock MPI with 13" height?
#3 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 27 February 2016 - 07:12 AM
Thanks for the reply. It's running 175/50/13 tyres, so I guess mpi sportspack would be the best comparison.
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 27 February 2016 - 10:34 AM
My car 1275 1993 running 6*12 wheels 165/60/12 tyres is at 240 front 270 rear(new rear cones)
#5 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 27 February 2016 - 11:21 AM
You probably won't find stock figures. I'd personally just play with it until it looks right front and back and is equal either side.
#6 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 27 February 2016 - 07:18 PM
Ok, thanks, it does look about right at the moment, everything new, bushes, cones etc, but it's all over the road with tramlining to the point I'd call it dangerous on some roads. Will try wheel alignment and see how it goes.
If that doesn't work I may swap to 12" with a slightly less deep dish.
#7 inim_repooc
inim_repooc
  • 417 posts
  • Local Club: not part of one
Posted 27 February 2016 - 07:36 PM
what tires are you running?
#8 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 27 February 2016 - 11:46 PM
Yokohama a539. Why?
#9 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 27 February 2016 - 11:48 PM
With alleycat reproduction wheels, don't know the offset but it's deep if that's the right terminology.
Chris.
#10 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 27 February 2016 - 11:50 PM
Thanks for that, much appreciated.
#11 nicklouse
  • 18,583 posts
Posted 28 February 2016 - 12:11 AM
to be honest you are going about it wrong. Set the height to what you feel is right then set the wheel alignment.
But here is some info for you.
10s I think.
B45E41B8-5397-4FE5-9DDA-228122CC8ED1_zps
#12 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 28 February 2016 - 12:59 AM
Thanks, appreciate that but wanted to get some kind of rough guide to what is normal ride height so I can work from that. Seems to me, even a slight difference in front ride height will make a big difference in bump steer and camber etc..
#13 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
#14 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 28 February 2016 - 01:02 AM
What is the factory setting?? 😳
#15 Dusky
Dusky
  • 5,322 posts
Posted 28 February 2016 - 08:30 AM
64mm between wheel and arch on the front, 84 mm on the rear. But that might be different on sportspack if the arches are Cut?
