Tools
17 replies to this topic
#1 ukcooper
ukcooper
  • 1,625 posts
Posted 26 February 2016 - 04:16 PM
Tool list to get you started , information nicked from here and there if you want a credit just pm me and ill stick it in.
If you have any suggestions yourself, or anything I've missed please add them to this thread.
You do not need all these tools it's just a guide for building up over the years.
ideal Christmas prezzys or birthdays presents .
the best place for help is http://www.theminifo...sked-questions/
Not doing spanners, trolley jacks, screwdrivers or axle stands or any safety stuff just get the best stuff you can at the time.
Tools faq
To start depends on the year of your mini if it pre 1990 then it should be imperial if it after 1990 then it should be metric but 99% of minis are still inperial.
but then it may depend on if people have changed nuts and bolt and if rover ever changed the size from imperial to metric.
Tips
See if you can get a trade card from Halfords or beg one, they do not tell you the discount that will be knocked off you have to go to the till and ask as it's per tool.
But for most Halfords tools they knock good money off and keep the recite forever if you want the life time warranty.
Why Halfords well there the most common place to get stuff for me and they isn't to bad at all.
Failing that go ask the family what they have you might be surprised what's tucked away??.
Safety glasses ( Yer I know ) under the car, grinding, messing with brake fluid you only get on set of eyes ( i told you so )
Knee pads or a good peace of foam to kneel or sit on, in 30 year's time you will wished you had listened.
Gloves there cheep these days use them.
Your best friend is wd40 or similar, if it is in the car or on the engine generally it dose not need spraying, if its outside the car and you think it needs spraying start spraying a week before removing and
twice a day if possible as it takes time to get penetrate deep into the rust.
If you need a one off tool like reamers for the suspension, engine lift's ect ask at the local club, Give them a deposit as a act of good faith and check it ok before you leave them and ask how it works,
clean it, do not abuse it and return it asap in the state you received it or better and if you break or lose it buy them a new one or come to some deal. People who have these tools know they wear out and break at times just tell them if it goes wrong.
Look on ebay for tools and you will find that certain expensive company's have the same looking tools with different name's on them, these are mass made and mainly are in the 99p bracket but a lot higher price.
Quality off tools = Money
Snap-on - top end loads of money only worth while if you in the trade or loaded.
Halfords, brit tool, look on ebay price's are all over the place but most have warranty's but good for a good 20 years or so. Also go down the parts shop and have a good look round.
Market stall and the 99p shop, Total crap to best tool's ever. you never can tell but if you ever need to grind a spanner, hit with big hammer or use a screw driver as a chisel these are the one's to use.
Respect
Respect the tool clean and polish them, select the right tool for the job, when there worn out throw them away or in the 99p draw.
When you don't show respect they will bite and hurt you ask 99% of people on here.
General tools
Decent set of imperial (that's inch, not metric) spanners/sockets
A second 1/2" and 7/16" spanner
1/4 drive imperial socket set
Torque Wrench
Posidriv & Philips screwdrivers
Tap & die set (imperial)
A magnetic tray to save you losing all those nuts and bolts
Coffee/sweet/jam jar of choice for storing nuts and bolts
A BIG hammer, or BFH, for those "rhubarb" moments
Rivet gun and rivets for those arches
Pliers
Mole grips
Wire brush(electric and hand)
Crowbar
Long needle nose pliers
Rubber mallet
Circlip Pliers
Roll Pin Punch
Center Punch
Brass Drift
Easy out
Hacksaw (junior and senior)
Brakes Specific
5/16" Brake adjusting spanner
Brake Pipe Spanner (7/16th's)
Eezebleed brake bleeding kit
One of those things for fitting circlips on rear brake cylinders
Engine Specific
Spark plug socket
Timing gun
Compression tester
Points File (anyone remember/got these)
Valve spring compressor
Piston ring compressor
6 & 7mm sockets and long extensions for jubilee clips.
Oil filter wrench
Feeler gauges
Dwell meter (multimeter may or may not include dwell)
Impact driver for door striker plates and such.
Flywheel locking tool (aka an old main bearing shell)
Flywheel puller and old drive shaft (use the drive shaft to "ring" off the flywheel, just smack it with a hammer)
Suspension Specific
1 5/16" Impact socket for Hub centre nut, disc braked minis. Also fits steering wheel retaining nut
1 1/2" deep socket for Swivel pin cups, all minis
Grease gun
BIG breaker bar for disc hub nuts
Cone compressor tool
Hub puller
Scissor type ball joint splitter
Electrical Specific
Multimeter
test lamp
Quality electrical crimping tool
Assorted crimps
Quality wire cutters
Wire strippers if you feel the need
Other Usefuls
Copper Grease (not technically a tool but, required)
Sand Paper/ Wet & Dry Paper
Masking tape
Labelling kit (so you remember where it all goes) post its, masking tape, bags, cardboard with holes
Blowtorch
Bottle of rust converter
A LARGE can of penetration oil (wd40 is ok, but plus gas kicks ass)
A roll of Gaffer Tape
Oil drain tray (an oil can with side cut out just doesn't cut it!)
A magnet on a bendy rod for retrieving dropped bolts
A third hand for all those jobs where two isn't enough
A nice cup of tea and a sit down
Torch (with a magnetic holder if possible)
SPECIAL WASHER FOR SEATING CV AND WHEELBEARINGS S/STEEL
CV BOOT CLAMPS
CV GREASE EAR PLIERS x1 GARAGE - for fitting cv boots that fail every few years
oetikertoolandclamps72-450_zpsr7hkcnkl.j
Sykes pickavant Acr4
Acr4 + you need a cable
4 line display for mpi/spi only
CLASSIC MINI BRAKE AND CLUTCH CLEVIS PIN FITTING TOOL
KGrHqZiYE5oq5oqPjBObmF-SCVQ60_57_zpsmeyj
Flaring tool
for brake pipes and clutch pipes
Flaremaster2 - The Original Hand Held Automotive Brake Pipe Flaring Tool
Features:
Quick-release chuck for positive engagement of the punch
Fast-turn coarse thread on hydraulic ram, for quick assembly
Locking bolt with swivel pin, for fast tightening
Inter-changeable dies, held in place by magnets
Enhanced bridge unit for greater strength
Ergonomic handle moulding, for greater comfort
Unique, original, patented design for producing high quality pipe flares - on the vehicle
Flaring pipes on the vehicle allows for accurate repair sections to be spliced following repair work or accident damage
Creates SAE & DIN single and double flares
Supplied in moulded plastic box
Contents:
- 02725600 - Flaremaster2
- 02165000 - Dual Size Brake Pipe Aid Plier
- 02210000 - Telescopic Pipe Tube Cutter: 3-32mm
- 02730000 - Pipe Deburring Tool: 3.2-16mm
Flaremaster2 - Spare Parts
02724470 - Flaremaster2 - Flaring Die Block Set - 6mm
02725170 - Flaremaster2 - 4.75mm, 3/16 OP1 Punch SAE
02726170 - Flaremaster2 - 4.75mm, 3/16 OP1 Punch DIN
02727170 - Flaremaster2 - 4.75mm, 3/16 6mm OP2
02726500 - Flaremaster2 - Set of Punches: 4.75mm, 3/16
02720470 - Flaremaster2 - Flaring Die Block Set: 4.75mm, 3/16
02725270 - Flaremaster2 - Replacement Clamp Assembly
02725500 - Flaremaster2 - Replacement Handle Assembly
02726070 - Flaremaster2 - Hydraulic Ram Assembly
02725570 - Flaremaster2 - 6mm OP1 Punch SAE
02726270 - Flaremaster2 - 6mm OP1 Punch DIN
Specifications
Weight - 2.8
Dim 1 - 300
Dim 2 - 350
Dim 3 - 100
Spare Parts - 02725000,02160000,02210000,02730000
Flywheel locking tool, very handy - somerford minis
Bolts in the starter hole and stop the engine turning over .
Oil seal tool / clutch tools
minispares - Ace tool for installing clutch oil seal.
if you don't use one off these make sure you tape up the spines on the crank/gear to stop damage
to the seal as the spines cut into the seal and cause another leak costing you pulling the engine out again and a
​new clutch also sets it to the correct depth and so easy to use.
Primary Gear puller - for pulling the gear off and the seal with it.
( this is a maxi engine puller as a mini one is longer )
to install or remove one of these
Flywheel puller
Make sure you take the washer out by the bolt.
They can be a right sod get off and with a bang to, heat and big bar.
Gear rod punch
For punching out the pin at the end of the selection rod.
Mini mine
KGrHqNicE-onHq5oeBP8qlJs0iQ60_57_zps6pnq
Synchrony Hub Ball & Spring Fitting Tool
Guesswork's
has available a Classic mini Synchro Hub Ball & Spring Fitting Tool. This tool is designed to aid the installation of the balls and springs within
the synchronisation gear hubs as fitted to any Mini or Metro with synchromesh gear engagement, or transverse equivalent, such as Midget, Marina, Ital, Moggy Minor.
Including 848, 970, 997, 998, 1071, 1098 & 1275 engines
Very simple and easy to use, if you have built a gearbox with one of these tools you will never want to go back to the old method
Instruction video available online
Slump plug
5/8 unc helicoil kit / read up about this before you do anything
crimping tool
Propa crimping tool
12v tester
Probly the most important tool in your mini tool box  :X
Multimeter
Jump leads
don't leave home with out them
Engine rebuild tools
Micrometers 0 - 1" , 1-2", 2-3"
Vernier calipers 0 - 150 mm
Depth micrometer 0 - 1"
Dial Gauge and stand 0 - 0.5" or 1"
Feeler blades 0.001 - 0.035"
If you can afford it a dial bore guage 0.5 - 1" and 2-3"
Telescopic guages
Small hole guages (not overly needed but nice if you have them)
Cam timing protractor
Taps for thread cleaning, 1/4" UNF/UNC, 5/16" UNF/UNC, 3/8" UNF/UNC
Torque Wrenches 5-20 lbft, 20 - 100 lbft, 50 - 250 lbft.
A centre lathe (or a friend who can do machining for you)
A vertical milling machine (or a friend who can do the machining for you)
Slip guages (definatly a luxury item, perfect for rocker geometry setting)
Plastiguage 0.001 - 0.003"
24in breaker bar at least 1/2" drive!
Length old scaffold tube (aluminium kind is best 4 ft in length)
4 ft growler bar.
Flywheel puller
Plumbers blow lamp (the kind that has a propane bottle separate to the torch)
Some means of brazing.
80 and 120 grit wet and dry paper for lapping.
320 and 1000 for polishing items
Bench grinder
Valve grinder (machine shop)
Valve seat cutters/grinders (machine shop)
A dremel or at least a drill.
Drill set
Straight edge 24 in (this is a luxury)
Burette 50cc
Helicoil inserts (Decent machine shop will have these)
A selection of needle files
Hand file medium cut 12 in
Bastard file 18in .
Gasket scraper (decent one)
Some means of checking camshafts (this could be your engine that you are building, or better still that old 998 engine you had in the corner of the garage stinking up the place!!)
Degreasing agents
Engine stand
Some of these tools need practice to be able to use accurately/safely so a freindly engineer is the best contact here. Others may need the services of you local machine shop, but remember it is up to you to check any machined dimensions to be sure that they are correct before you build the engine.
Brake tools
buy the tool in advance
KGrHqViMFCeylWzTBQ7rURpMVQ60_12_zpsul66j
or to free two hands try this, The Shifty Way!
d6e63f46-a8cb-4089-909d-8f69326ddbff_zps
REAR BRAKE ADJUSTER TOOL
Easy bleed
Bleeding brakes on your own
If your fitting front pads get a new set of these as well.
For squeezing the spring on rear brake
Taps
taps you need a correct drill size, hats small than the tap .
Hard as ******* when they break - you can not re drill them needs to be taken to a machine shop.
5/8 16 uns - crank shaft
5/8 18 unf - Head Temperature hole 37/64" drill bit
5/8 unc - sump plug
Austin Crankshaft 5/8" x 16 Whitworth Special Tap (Whit Form)
The nose (damper) and flywheel (tail) end of Classic Mini and all transverse Austin, Morris, British Leyland, America, 1100, 1300 and Rover crankshafts, and the nose pulley end of all inline crankshafts such as Marina, Ital, Midget, sprite, moggy minor and many more.
Including 803, 848, 948, 970, 997, 998, 1071, 1098 & 1275 engines
This tap is not a Whitworth Fine which technically does not exist.
The thread in the crankshaft is not 5/8 inch unf, unef, uns, Whit Fine or WF, as these are all incorrect in one way or another.
This thread size, type and pitch was also used on the by-pass hose pipe 12A2075 that screws into the head on earlier models.
Wrench and power bars
These come in a few sizes and in this country they are imperial and the basic one's are 1/4" 3/8" 1/2" and big boy's toys 3/4".
Now spend some money as cheep one's break and slip and that results in money and blood.
1/4" drive are great for tight spaces and upto about 11mm max.
3/8" drive are i guess the all rounder from 8mm to about 17mm.
1/2" drive are for the bigger nut's 17mm to power bar size.
Power bar, breaker bar this is maily for undoing nuts that a rachet may slip when used p.s. they do break.
facom-s_141a-power-bar-1-2-in-drive-7074
Sockets
Sockets there are few kinds 6 point and 12 point deep and shallow and standard metric imperial.
20020701_Which_Should_I_Buy_page002img00
Me i try to stick to 6 point as there a little better chance of not rounding the nut off but if your going to use apr nuts then you 12 point sockets.
Deep socket great peace of kit as they keep your knuckels away from the car and a god send for exhaust clamps,
the down side is you have to keep them stright and square to the face of the car part.
Standard sockets better as they sit close to the face of the car part, now id get decent set for every day use and a cheep set that you can hammer on to rustey bolts.
Socket sizes
1"1/2 Deep= Ball joints / Gearbox internal / Flywheel
15/16" or 24mm = Sump plug
1"1/8 = Gearbox internal / Drum Brake Hub Nut / Crank Pulley Bolt
1"3/16 = Verto nut
1"5/16 = Hub nut / Tower Bolts / S-Wheel Boss /Fits crank pulley bolt / camshaft nut / post-76 front Subframe tower bolt
11/16" = wheel nut's
1" = oil re leaf nut
Wind screen tool
DONT NOT USE FAIRY LIQUID AS IT GOT SALT IN IT AND ROT'S THE RUBBER.
Cone tool
Two types imperial and metric after 1976
Metric thread is the coarse one, but the imperial one will fit and go in and then strip while your finger are around ???
Ball joint splitter
Note any damage to the rubber's is a mot fail from the 4/2012
Read me!!!!!!!!!!!!!!
Tool Envy Syndrome (TES)
Tool Envy Syndrome (TES) is a serious condition that afflicts, in varying degrees, nearly all men who are interested in mechanical things. It is very important to recognize and deal with this condition before it becomes serious; left untreated it can lead to a far more serious condition: Inflammation of the Credit Card (ICC). TES is known to strike under the following circumstances:
Browsing the latest tool catalogs or sale flyers
Visiting stores such as Grizzly or Harbor Freight (Warning: while much less so than in earlier years, the tool department at Sears can still trigger small attacks)
Visiting the shop of a friend who has more and/or better tools than you have
Surfing the web site of someone with a well-equipped shop
Seeing a well-equipped shop in magazines such as Home Shop Machinist
Tool Envy Syndrome tends to strike young men particularly hard, due its close relationship to a similar condition: Gear Acquisition Syndrome (GAS). Over time, in most men, both of these conditions tend to lessen in severity. In fact, it can be shown that gradual accumulation of tools and gear over a period of years can control both conditions while minimizing the risk of Inflammation of the the Credit Card (this is known as the Mature Phase). It has also been widely observed that getting married and having children can moderate the risk; primarily, it is believed, due to counseling from a loving wife and the sobering effect of having lots more bills to pay.
Tool Envy Syndrome cannot be controlled by any known drugs (although its effects can be exaggerated by the use of alcohol). Therefore, treatment is currently limited primarily to counseling methods. The first step is admitting that you have a problem. Here are some additonal pointers:
Avoid situations that are likely to cause an attack
When visiting tool stores, leave your credit card at home (Warning: in severely afflicted individuals this can trigger emotional breakdown, fits of crying and other irrational behavior)
Meditate on the fine collection of tools that you already have; recognize that time will make it better
Find a quiet place. Visualize your ideal shop. Repeat to yourself "It is coming"
I hope you have found this information to be helpful. As a TES/GAS sufferer myself (now in the Mature Phase) I felt compelled to pass it on to you.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted part which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ''What the...??''
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminium sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while wearing them.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling ''DAMMIT'' at the top of your lungs. It is also, most often, the next tool that you will need.
Part 2 below
Edited by ukcooper, 13 March 2016 - 07:00 PM.
#2 inim_repooc
inim_repooc
  • 417 posts
  • Local Club: not part of one
Posted 26 February 2016 - 05:09 PM
Everything seems to be there, just forgot the kitchen sink!  This would be good pinned in the technical section so people can be refereed to it maybe?
Top Job!  :lol:
#3 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 27 February 2016 - 01:53 PM
Nice/funny...correct the 20 or so spelling mistakes and it could be termed clever as well...like it a lot
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 27 February 2016 - 02:12 PM
Spelling not is my best point or grammar
#5 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 27 February 2016 - 03:21 PM
not a criticism...we all have different skill sets
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 27 February 2016 - 05:44 PM
This is the mini forum, not University Challenge.
As I've said on a previous post, you seem to be determined to upset people today. Did someone get out of the wrong side of bed?
#7 Archived1
Archived1
  • Archived
  • 619 posts
Posted 27 February 2016 - 06:12 PM
Thats a decent post mate, must have taken a while to put that lot together. A good adddition to the site!
Thanks very much
#8 ukcooper
ukcooper
  • 1,625 posts
Posted 27 February 2016 - 07:55 PM
Top 10 Must-Have Restoration Tools
http://www.theminifo...-tools/?hl=tool
Spark plug stuff
KGrHqJrQFEdQoLjLBRf-OemoeQ60_12_zpst3mde
3/8" Pre-set Limited Torque 23 Nm 280mm Ratchet Wrench for Spark Plug
Spark Plug Wrench Limited Torque 23 Nm 550mm
• Suitable for cleaning corrosion and carbon build -up from spark plug threads.
• Also possible to restore minor cross threading damage.
• Use with a spark plug socket (21mm).
• Model No. VS525
Head valve tools
For lapping in the vales
the gunson ones for lazy people like me who use a power drill
E3E53075-19D8-40E2-8811-71CF8661E13C-lar
torque wrench
a tool used to precisely apply a specific torque to a fastener such as a nut or bolt. It is usually in the form of a socket wrench with special internal mechanisms.
Make sure you get one with a case , treat it nicely I use 1/2 for head bolts and 3/8 for other stuff .
They come in 1/4 3/8 and 1/2"
General tool kit
should have spanners ,sockets, plies , screwdrivers and a rac card or aa or summit .
Wheel socket / especial for the chrome covered ones
11/16 socket for wheel nuts not 17mm and 6 point
133adb0d-b2b2-4318-9eaf-daf2f54a85d9_zps
Clikadjust Tappet Adjuster
For doing tappets , check with feeler gauges after to make sure there correct
3ABC207B-CC8F-4A96-9FDF-94657247F7C8-lar
Colortune Single Plug Kit
plugs 1 and four for lean and plugs 2 and 3 for rich
C1776135-ACA1-43FC-A018-1810E4D3EF1C-lar
Timing light
For dong the timing carb models only ​read up on what you want out of it.
73751BE9-5755-49EC-A3F5-C46E2D068A80-lar
Camber Gauge
Read up on these
50EE53F7-3A30-496E-97A8-4DF5464E0158-lar
Compression Tester Kit
Tells you when the engines in need of tlc.
2 people , throttle wide open, OUT OF GEAR dose not matter to much about the reading as long as there all the same.
all the plugs out write down the results, spoon full of new oil down the plug hole and re do the test and write that down.
2C412BCE-E797-4363-AECC-F919BFB1D7F8-lar
033AE85F-57B3-4785-AB7A-5C06164298F3-lar
Edited by ukcooper, 15 March 2016 - 06:43 PM.
#9 ukcooper
ukcooper
  • 1,625 posts
Posted 27 February 2016 - 08:00 PM
Cheers for the comments people :)
#10 Alex_B
Alex_B
  • 4,573 posts
Posted 27 February 2016 - 08:45 PM
Could do with a little formatting to bold the titles and whatnot just for clarity but its certainly a very complete list and I can't think of much else to add that I use day to day. But yes would be good to pin this for anyone new to spannering on older cars.
-A bearing / seal press tool is very handy for wheel bearings and certain oil seals, means you will get them sitting square and tap them in a little easier.
-Left handed drill bits, they tend to work better than an easi out which will cause all manner of pain when it inevitably snaps flush and then cannot be drilled out, where as a left hand drill will drill out the stud as per any drill bit but can sometimes grip the broken stud/bolt and actually back it out of the hole without needing to completely drill out the stud.
- Impact gun, for removing very stubborn bolts but never to be used to do up any bolts that are lower than its total torque especially not wheel nuts!
If those are in your list then I apologise, I dont think I saw them.
#11 ukcooper
ukcooper
  • 1,625 posts
Posted 28 February 2016 - 03:26 PM
HT Lead and Ignition Spark Tester
One of the most useful little tools you will have in your tool Box
Quickly test for a  ignition spark by fitting between Spark Plug and HT lead , Car will run as normal when fitted .
Made from a translucent plastic a bright flash can be seen with every spark .
Mole grips
Various shapes and sizes . keep one set decent for removing bolts ect, another set for welding ect.
Right Hand Drill Attachment / or left hand.
For hand or power drill use•Right-hand or left-hand use •1.5mm-10mm capacity
allow your drill to access those difficult-to-reach areas.
Dremel
Dremel is an American brand of power tools known primarily for its rotary tools. Dremel's rotary tools are similar to the pneumatic die grinders used in the metalworking industry by tool or moldmakers
Drill bits - Left handed drill bits
they tend to work better than an easy out which will cause all manner of pain when it inevitably snaps flush and then cannot be drilled out,
Stud removers - easy outs
Desperate times these are made for . last chance saloon . there hard as ******* and they break quite easy and its the machine shop if you do break one.
Impact gun,
Bearing / seal press tool
Very handy for wheel bearings and certain oil seals, means you will get them sitting square and tap them in a little easier.
slogging spanner
Not cheep but a 1"1/2 is great for very old stuck ball joints.
striking face box wrench
slammer wrench
slugger wrench
hammer wrench
Edited by ukcooper, 17 March 2016 - 05:33 PM.
#12 ukcooper
ukcooper
  • 1,625 posts
Posted 28 February 2016 - 07:33 PM
Spare
#13 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 28 February 2016 - 08:50 PM
I was lucky my friend who was a mechanic moved abroad and sold me all his tools for £160 this included a bluepoint socket set and mig welder .
#14 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 06 May 2016 - 09:45 PM
Anyone ever build an engine test stand to run in the cam or do other tuning out of the car? I build quite a few Mini engines a year, so I'm in the planning stages of one.....ideas would be helpful. I already have the frame knocked up out of the frame from an old treadmill (free metal is good metal!) and I have gauges on order - oil press, water temp, voltage and tacho.
If anyone would like to see it I can put up a build thread separately......but I consider it a tool so appropriate for this thread - which is great by the way!
Edited by Magneto, 06 May 2016 - 09:46 PM.
#15 Alex_B
Alex_B
  • 4,573 posts
Posted 06 May 2016 - 09:54 PM
We have one at work for running in and setting up of Jag xk6 engines. It's not much more than a large frame / trolley to which there are a couple of engine mounts, a fuel tank, a header tank and rad with fan, an exhaust system set up on it with a couple of lambda gauges and then a tacho, oil pressure, water temp and afr gauges with a battery and coil. You ideally want a good extraction system though so you don't give yourself carbon monoxide poisoning!
