Priming Oil Pump
15 replies to this topic
#1 crn1969
crn1969
  • 114 posts
Posted 26 February 2016 - 12:30 PM
Will be fitting a new oil pump at weekend have read important to prime it? How do I go about this.and with what?someone said grease?
#2 Daniel_moody25
Daniel_moody25
  • 407 posts
Posted 26 February 2016 - 12:32 PM
fill it with oil
#3 Ivor Badger
Ivor Badger
  • 846 posts
Posted 26 February 2016 - 12:51 PM
Don't fill it with grease, oil as pointed out is quite sufficient. The "grease" trick was for Rover V8s and you didn't use grease. it was "Vaseline" or petroleum jelly which dissolves easily out the pump without blocking the oil ways. It's why you shouldn't use the stuff as a sexual lubricant with condoms, as the mineral base destroys the rubber.
#4 blacktulip
blacktulip
  • 6,224 posts
Posted 26 February 2016 - 01:16 PM
Is it ok for the oil to pour out when attaching it to the engine?
#5 crn1969
crn1969
  • 114 posts
Posted 26 February 2016 - 02:11 PM
I was thinking the same as I mount the pump vertically won't the oil pour back into block?
#6 peterh2
peterh2
  • 44 posts
Posted 26 February 2016 - 02:53 PM
The 998's (pre A+) have a priming plug on the block.
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 26 February 2016 - 03:18 PM
I've read somewhere that on the other engines you prime it via the oil filter pipe.
You remove the large banjo bolt on the block and fill the pump slowly while turning the engine backwards ...
Is that true?
Edited by gazza82, 26 February 2016 - 03:24 PM.
#8 Ivor Badger
Ivor Badger
  • 846 posts
Posted 26 February 2016 - 03:25 PM
I've read somewhere that on the other engine you prime it via the oil filter pipe.
Is that true?
works when you forget to prime while building or it's lain too long. just turn the engine back a turn after priming.
#9 Cooperman
  • 23,276 posts
Posted 26 February 2016 - 07:44 PM
Best thing is to use engine assembly lube.
If you wish you can 'back prime' as well after final assembly through the oil pipe hole on the front of the block.
#10 crn1969
crn1969
  • 114 posts
Posted 26 February 2016 - 08:31 PM
Many thanks excellent knowledge as always on here.
#11 crn1969
crn1969
  • 114 posts
Posted 27 February 2016 - 12:22 PM
When u describe the hole on the block do you mean where the external pipe that that is connected to oil filter is attached ? top left corner of block ?
#12 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 27 February 2016 - 12:47 PM
Just use assembly oil, when you start the engine, take off the king lead and crank till the oil pressure registers, and then start.
#13 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 27 February 2016 - 01:53 PM
Yes. I need to find out where I read that.
My engine will be stored for a while as I rebuild the rest so I have a chance to refill the pump before it goes back. I'm using lubriplate and assembly oil I bought from minispares.
#14 MRA
MRA
  • 7,607 posts
Posted 27 February 2016 - 06:31 PM
Fill the oil pump with oil and it will drain out, but it will hopefully of worked it's way around the internals of the pump, but if you have engine assembly grease (lithium) this is better, you can also strip the pump and cover the internals that way, then back fill using the oil pipe from the filter, also fill your oil filter fully, let it soak in and then fill it again.... then fit it carefully. so as not to empty it.
Turn your engine over with the spark plugs out to get oil pressure (do NOT forget to disable the ignition as any spark could ignite the fuel from the spark plug holes)
#15 MRA
MRA
  • 7,607 posts
Posted 27 February 2016 - 06:35 PM
Why are you using condoms in your engine ?  and what on earth would engine oil be in a condom for ????
