What Gear Ratio Are You Using
Posted 24 February 2016 - 05:56 PM
Posted 24 February 2016 - 09:45 PM
Posted 24 February 2016 - 11:22 PM
So you guys might need the services of a gear cutter then.....
Posted 25 February 2016 - 05:36 AM
Posted 26 February 2016 - 10:11 AM
Hi what gear ratio are you using I have a 2009 k20z4 and it's reving to hight at 60/70mph just wondering what ratio is best and where I can get one from thanks
Original FD in the K20A2 EDM EP3 is 4.764.
Here's the Honda part number for a 4.389 final drive kit: 23227-PNS-305 about £500 for OEM parts and a possible lead time of a few weeks.
I am using a 3.9FD hitting 60 in 2nd gear at the rev limiter, cruising at 70mph=approx 3400-3500rpm in 6th (from memory). It will do approx 150mph in 5th and god only knows what it'd do in 6th at the rev limiter. This all done on 225/45 R13 Toyo R888's
by the way, I haven't ordered or used the part number I've supplied but I believe it is a direct Honda replacement.
Edited by cptkirk, 26 February 2016 - 10:14 AM.
Posted 26 February 2016 - 10:49 AM
Posted 26 February 2016 - 11:25 AM
the 3.9 is a Zcars supplied part, unsure if they are still able to get them though????
If I were to do this again I'd go for a 4.3 and then look to swap out the 6th for a nice tall gear, I think the TSX has a taller 6th??. You can find K20 gear ratios on the net and also gear ratio calculators that allow you to put in tyre size, gear ratios, FD and revs and it'll give you the speed achievable in each gear at the rev limiter.
Be warned that if Zcars get their FD from the same suppliers then the holes in the FD are 10mm not 11mm and you'll need to get them spark eroded to 11mm to make them work with an OEM or Quaife diff. An extra cost I did not foresee.
Posted 27 April 2016 - 06:50 PM
WOW Cpt KIRK - busa engines have same problem, but its easy to just swap over front or back sprockets. think mine will do about 125mph from memory.
