Bmw 16V K1100 1380 Engine
847 replies to this topic
#121 Streetscreamer
Streetscreamer
  • 16 posts
  • Local Club: Mini Seven Club Netherlands
Posted 21 June 2016 - 11:29 AM
regulator: as you are building an injection system you have two choices, one or two line system.
With the one line system the regulator will be close to the tank, the overflow will be returned immediately to the tank. Only one fuel line with regulated pressur ewill go to the engine.
With the two line system the regulator will be placed in the return line, close after the injector fuel rail. As you could see in the original BMW K setup.
Experience tells me the two line system handles better with sudden pressure drops created by batch injection. Even better you can place an accumulator in the delivery line.
#122 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 21 June 2016 - 07:21 PM
Yes I will run a two line system. It is already in place in the car (SPI).
I did wonder whether it should be placed on the return line or not, you confirm what i thought.
#123 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 21 June 2016 - 07:27 PM
I bought a 180 U shaped silicon hose for the head to block coolant (due to the dry decking). However, the crank breather is kinda in the way, so i had to trim  fair bit of the hose, in the end i wasn't really happy with the fitting. I will instead run 2 90 degree hoses with a join. Here is one 90 fitted (needs trimmed), i just need to buy another.
C1E242E6-CAA5-4468-BBB6-26CAB9377C27_zps
I also fitted the new standard crank dampener and torqued it up.
1CDD3765-9DE1-4645-AB58-25AF52E0A12C_zps
I wonder if the crank positioned sensor pick up is close enough to the trigger wheel?
5098AA00-52DE-443F-9D33-8ECEF25D4CAD_zps
55DCF4F8-29E5-4E22-BA81-BDDB0E958A5D_zps
#124 Streetscreamer
Streetscreamer
  • 16 posts
Posted 21 June 2016 - 07:57 PM
Sensor: often a gap of 1 - 1,5mm will do. But be sure the center of the sensor will be in center of the trigger wheel in order to have the best functioning.
Hose: so great to see your build as I will face the same issues soon. Currently the engine block is being decked in the machine shop for forged omega flat tops (with pockets). I have also drydecked the engine so for this matter I already bought two 90 drgree elbow hoses. They will be linked by a fleabay-chineze piece of anodized alloy for mounting a temperature sensor. But then this will become my take-off for the interior heater.
General: your photographing is telling so much and is very much apetizing !
Keep up the good work!
regards from Holland, Bart
#125 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 21 June 2016 - 08:32 PM
Yes I think I will ask SC to send one more spacer to bring the magnet into the centre of the wheel.
#126 nicklouse
  • 19,058 posts
Posted 21 June 2016 - 08:38 PM
You need an earlier breather can. I have a spare. Will take pics. And if you want it it will cost postage.
Attached File  image.jpeg   10.87K   4 downloads
Like this. Or you could get a breather part form DSN or modify yours.
#127 nicklouse
  • 19,058 posts
Posted 21 June 2016 - 08:58 PM
Or maybe not if you have the servo there.
#128 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 21 June 2016 - 09:12 PM
 Yip I will have the servo!
I have ordered another 90 hose and a joiner. If it doesn't work I will look at the DSN part
#129 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 June 2016 - 09:38 PM
Some final bits arrived today:
4.2 inch MED water pump pulley
nippon denso alternator
Engine mount "plate" all the way from Barcelona (wasn't the easiest to find)
a 90 degree hose and connectors.
3111B792-343E-428E-B752-01EF1BC60E2F_zps
Well the 4.2 inch  pulley clears the oil hose perfectly.
C892F70A-A0D8-491E-ACFE-ADC9D4377852_zps
It is amazing how small the denso alternator is!
86268F65-ACB3-46F4-BB48-EAA8641D23C9_zps
Seems like the 90 degree hose i tried to use before was pretty poorly made, I.E it wasn't actually 90 degrees. the new ones seems to fit much better. I will order one more and use a joiner and it will clear the crank breather just fine.
3D963155-4291-4547-B874-D12CD7635AB9_zps
Seems like the fan will not clear the oil hose. This hose had been a bit of a pain (see water pulley issue above). It was supplied as an add on to the kit. I think i will need to shorten the "legs" both sides of the cam belt.
Next up is the clearance between the crank damper/trigger wheel and the radiator/engine mount bracket.
C34CC816-0A21-4002-9ED1-C33B3017DC2B_zps
It clears but it is extremely tight.
55C70ACF-654D-4CC3-B998-CEC9721D1B49_zps
53F1A51E-9FBE-4709-B827-4BE9CAECC7CD_zps
I hope it is enough just to grind the bracket a little?
#130 nicklouse
  • 19,058 posts
Posted 23 June 2016 - 09:41 PM
I would grind it a bit where needed. Also look at slotting the holes for the rad bracket so you can slide it away if needed.
#131 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 June 2016 - 09:52 PM
good idea!
#132 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 June 2016 - 09:55 PM
looking at the gearbox/speedo housing/engine mount plate. It seems that it should be bolted to the speado housing using studs. (below).
Screen%20Shot%202016-06-23%20at%2023.48.
Not knowing this I have actually used 3.25 inch bolts. they are torqued up to 25nm
I guess this will be alright?
#133 nicklouse
  • 19,058 posts
Posted 23 June 2016 - 10:18 PM
Mmmmmmmmm.
The idea is the UNC thread is in the alloy and the nuts are torqued so you are only pulling on the UNC threads not rotating.
Using bolts you could lift the thread causing potential oil leak issues.
#134 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 June 2016 - 10:21 PM
Mmmmmmmmm.
yeah I figured that if studs are what should be used then i should use studs. I just ordered the studs. (only a fiver or so)
#135 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 June 2016 - 10:30 PM
Mmmmmmmmm.
Hold on! actually just checked again and the info on minispares suggests that bolts where used after 85.
Screen%20Shot%202016-06-24%20at%2000.27.
